| View previous topic :: View next topic |
| Author |
Message |
andypitts
Posted: Fri Jun 26, 2009 10:10 am Post subject: Membrane above celotex insulation? |
Am planning to insulate between the sloping roof rafters in the attic of a large 1860's stone built semi.
As it happens, the next door semi is having their roof slates replaced at the moment. Like mine, these are the original thick old Welsh slates - and there is no felt beneath them at all ie they rest directly on the wood sarking boards with the attic space underneath this. So the builders are laying down a breathable waterproof membrane on the sarking first to then lay the new slates on top of.
I can't afford a new slate roof myself but am worried that old cracked slates plus no underlying felt = leaks into the attic space.
Should I pin some membrane pieces up to the underside of the sarking boards first before fitting the Celotex insulation panels in place?
Maybe I can use the same membrane next doors builders are using - says M7550-1B on it?
Cheers |
| Back to top |
Posted: Fri Jun 26, 2009 8:09 pm Post subject: |
andypitts,
Replace the broken slates and fix the insulation under the rafters so that there is a ventilated gap between the boarding and the insulation.
end |
| Back to top |
bd3cc
Posted: Fri Jun 26, 2009 10:31 pm Post subject: |
| Think you could be wasting your time. Sorry! |
| Back to top |
andypitts
Posted: Sun Jun 28, 2009 9:18 am Post subject: |
thanks but not not sure in what respect I might be wasting my time?
cheers |
| Back to top |
Perry525
Posted: Mon Jul 06, 2009 6:03 pm Post subject: |
Its hard to understand where you are going with this?
Lets start by saying that "old Welsh slates" may be old but, they are good for four hundred years (if they are Welsh slates.)
So, why would anyone wish to disturb them?
Have the nails gone?
Do the slates rattle in the wind?
One type of repair is to slide a piece of aluminium under the slate, cut to size it will be invisible.
I have seen roofs where they have been glued together.
Your slates seem to have worked well for over a hundred years, without a membrane........... |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
