DIY Doctor
Permaroof
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: DeWalt D25701KL 110V 7kg SDS Max Combi Hammer DIY Doctor: Screwfix: Caterpillar CAT Yellow Lens Digger Safety Specs DIY Doctor: Screwfix: Erbauer Pozi 2 Contractors 20 Piece Bit Box DIY Doctor: Screwfix: Finnlife Kolka Log Cabin
Share and bookmark DIY Doctor
Replacing 2 lintels in a loadbearing wall with an RSJ
Post new topic   Reply to topic    Diy Doctor Forum Index -> Conversion, refurbishment & renovation
Author Message
jimuthy
PostPosted: Sat Aug 15, 2009 2:35 am    Post subject: Replacing 2 lintels in a loadbearing wall with an RSJ Reply with quote
My semi-detached house was extended to the rear in the distant past in order to increase the size of the kitchen. While much of the brickwork of the former external wall was removed, the house was left wth a brick column 800mm x 300mm slap bang in the middle of the room (e.g. the brickwork between a 900mm door opening and a 1750mm window opening). The brick column supports two lintels which are then built into the brickwork on either side of the former door and window openings.
I would like to get replace these lintels and column with a single RSJ spanning the full 1750mm (e.g. 900+800+1750)- what is the best way of going about this?
Back to top
eljaybee
PostPosted: Sun Aug 16, 2009 6:48 am    Post subject: Reply with quote
You need to get an engineer to produce you the calculations for the size of the steel and any padstones required and then make a building regs application for the strucutral alteration.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Conversion, refurbishment & renovation All times are GMT
Jump to:
