DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Volex Switch Socket DP 2G 13A DIY Doctor: Screwfix: Aluflash Roll Flashing Embossed 300mm x 5m DIY Doctor: Screwfix: Titan Auger Bit 20 x 200mm DIY Doctor: Screwfix: Emergency Rotary Hand Bell
Share and bookmark DIY Doctor
best way to grout
Post new topic   Reply to topic    Diy Doctor Forum Index -> Tiles & tiling
Author Message
rambo77
PostPosted: Fri Sep 04, 2009 10:01 am    Post subject: best way to grout Reply with quote
what is the best technque for grouting without making a mess of the tiles obviously its best to remove as much grout of the tiles before it dries but what is the best way without messing up the grout itself
also should the grout be brought up flush with the tile!!!
Back to top
bd3cc
PostPosted: Mon Sep 07, 2009 10:37 pm    Post subject: Reply with quote
Wipe the grout vertically and horizontally with a wetish sponge so that you have a thin film of grout over the tiles, that can be polishes off with a dry cloth.
A circular motion may be best initially.
Usually the grout sits slightly below the tile face.
Do not leave any large amounts of grout when wet. Grout will not damage the tiles in a thin film and is better removed dry.
Back to top
rambo77
PostPosted: Sun Sep 13, 2009 7:56 am    Post subject: Reply with quote
so basically what your saying is to grout with a sponge and not a rubber trowel....????
thanks for the advice
Back to top
bd3cc
PostPosted: Sun Sep 13, 2009 4:39 pm    Post subject: Reply with quote
You can apply the grout with a rubber float to force it well into the joints, but I would still wipe of with a sponge.
The grout will find its own level slightly below the surface of the tiles.
HTH
Back to top
acsimpson
PostPosted: Mon Sep 14, 2009 9:32 am    Post subject: Reply with quote
I've always found the slight extra work of using a grout profiler (or just a finger) to give an even finish to the profile worth the work.
When you are wiping with a sponge be carefull not to follow the line of the grout or the sponge can pull the grout out of the joint.
Back to top
rambo77
PostPosted: Fri Sep 18, 2009 1:12 pm    Post subject: for bd3cc Reply with quote
i have done quite a few tiling jobs but always struggled with th finishing grout part so this time i tried using your advice with excellent results and alot of time saved
great advice thanks again!!!!
will be doing things this way in future
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Tiles & tiling All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
