DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Labgear Grey Speaker Cable DIY Doctor: Screwfix: Volex Weatherbox DIY Doctor: Screwfix: Trend Kitchen Fitters Pack No. 2 4Pc DIY Doctor: Screwfix: Halolite Fixed GZ/GU10 Satin Silver Mains Voltage Downlight
Share and bookmark DIY Doctor
After Stripping Wall paper
Post new topic   Reply to topic    Diy Doctor Forum Index -> Decorating
Author Message
Billy Nomates
PostPosted: Sat Sep 19, 2009 2:46 pm    Post subject: After Stripping Wall paper Reply with quote
I have just stripped woodchip paper off the walls.
It has left some residue paper behind.
Whats the best way to remove this
Should I use sugar soap and a sponge or some
kind of hard brush.
:roll:
Back to top
theshedman
PostPosted: Mon Sep 21, 2009 7:36 am    Post subject: Reply with quote
Hi Billy Nomates, just wet it and scape it off. Put a little bit of washing up liquid in the water. Then if it's still a bit messy after that wash the walls down. Are you painting the walls afterwards or wallpapering again?
Back to top
Billy Nomates
PostPosted: Tue Sep 22, 2009 10:52 am    Post subject: Stripping Walls Reply with quote
Hi Thank you for helping me out. As you probally guess by my User name
I don't have many people I can ask and its embarrassing as I should already know these things.
I have done as suggested and washed all the walls down with soap and water and have now removed all the residue left.
The walls do have a number of scuff marks (not from my Scraper ) already there.
I want to emulsion the wall and not replace paper.
If I lightly sand them then use some kind of \flash liquid with water and thoughly wash the walls. Whats the best thing to use to cover some of the scuff marks or will a couple coats of Emulsion paint do the trick.
If I use some kind of filler to cover the larger marks like for example the drilled holes should I use a flexible filler thats now available or should I use a Polly filler powder .
Any suggestions will be gratefullt recieved. As you can guess this is totally new to me.
Back to top
theshedman
PostPosted: Tue Sep 22, 2009 6:45 pm    Post subject: Reply with quote
Hi, I would make sure all the paste is off the walls first then use polyfiller to fill all the marks and drilled holes. The flexible filler is not really any good for this type of thing, but it is good for going around the skirting boards and the edge of the ceiling and around the doorways. After this give them all a light rub down to get them flat before giving them a couple of coats of emulsion. You will need to thin the first coat of emulsion as the walls will probably be porous after all the work you have done on them. If the walls are not nice and flat I would not use a vinyl silk finsh as it will show up everything. A matt finish will hide more than a silk one. Good luck with it.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Decorating All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
