DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Briton Euro Cylinder 90mm Deadlock Stainless Steel 60mm Backset 72mm Centre DIY Doctor: Screwfix: Bosch GBH5-38 6kg SDS Max Combi Hammer 230V DIY Doctor: Screwfix: Modular Black 1/4 Blank Plate DIY Doctor: Screwfix: Fluidmaster Flush Pipe 12" x 8
Share and bookmark DIY Doctor
fixing curtain poles to plasterboard ceiling
Post new topic   Reply to topic    Diy Doctor Forum Index -> Fixing to walls problems
Author Message
littlemouse
PostPosted: Mon Oct 19, 2009 8:06 pm    Post subject: fixing curtain poles to plasterboard ceiling Reply with quote
I have looked for similar queries but can't quite find an appropriate answer. Here is the problem:
I am having to fix a curtain pole to a hollow plasterboard ceiling. I can't screw it in to the window frame or the wall because our landlord has already fitted wooden blinds that we can't remove. On drilling the holes for the screws I found that two sets of holes are into the joists to which the plasterboard is attached and the other two corresponding sets on the opposite side just go straight through the plasterboard and subsequently there is nothing to screw into. I don't quite understand how this can be as I thought one joist ran from one side to the other.
I have been looking at spring toggles and want to know if these are the correct items for this job or if I should be using something else?
I am a bit worried that the plasterboard is not in good condition.
Back to top
moger4
PostPosted: Fri Nov 13, 2009 7:44 am    Post subject: Reply with quote
the best way to do this would be to fix a batten to the cieling , maybe with a nice edge painted , and then fix to this , fixing it secruely to the joists
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Fixing to walls problems All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
