DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Loctite Superglue Ultra Gel 3g DIY Doctor: Screwfix: Pick & Mattock Fibreglass Handle DIY Doctor: Screwfix: Single Radiator 2269 BTU 665W 600700mm DIY Doctor: Screwfix: Socket Cap Screws A2 Stainless Steel M6 x 20mm Pack of 50
Share and bookmark DIY Doctor
Curtain fixing - plaster wall
Post new topic   Reply to topic    Diy Doctor Forum Index -> Fixing to walls problems
Author Message
sween
PostPosted: Wed Jun 10, 2009 11:23 am    Post subject: Curtain fixing - plaster wall Reply with quote
I know this is very similar to other topics in here but there are loads of different answers so thought I'd give a precise description.
I fixed up curtains to the plaster wall in my flat a couple of weeks ago. The fixings are a hook on which you lay the curtain rod. Each hook has two screws that secure them to the wall - a long one and a shorter one. The longer one had a rawl plug in it.
Unfortunately, the plaster crumbled away from the screw fixings on one hook and the curtain rod just fell down. The fixing on the other end seems okay for now.
My landlady suggested filling the hole with polyfilla and screwing the screw back in with a rawl plug. I have my doubts as to whether this will work as the plaster around the filler will be pretty crumbly. I will try it, but would like to know if there are any more reliable solutions first!
Please help!
Back to top
PostPosted: Fri Jun 12, 2009 7:39 pm    Post subject: Reply with quote
sween,
You need to drill deeper and fix into lintol above the window which will be either concrete or steel.
Back to top
januspilot
PostPosted: Mon Oct 19, 2009 9:41 am    Post subject: Reply with quote
Try using the DrylinePro fixing. This will work great assuming that your walls are dot and dab which is what it sounds like.
Richard
Back to top
bd3cc
PostPosted: Mon Oct 19, 2009 9:15 pm    Post subject: Reply with quote
How old is the property?
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Fixing to walls problems All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
