DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Hitachi 10.8V Drill Twinpack DIY Doctor: Screwfix: Makita DC1804F 1hr Battery Charger DIY Doctor: Screwfix: Scheppach UST2780 Multi-Purpose Leg Stand DIY Doctor: Screwfix: Honeywell Dummy Alarm Siren / Bell Box
Share and bookmark DIY Doctor
UPVC door adjustment
Post new topic   Reply to topic    Diy Doctor Forum Index -> Carpentry & Joinery
Author Message
sfieldsend
PostPosted: Thu Jan 29, 2009 10:32 am    Post subject: UPVC door adjustment Reply with quote
My front door does not fit easily into the frame when closing. It catches on the top (open) corner. Is there any way of adjusting the hanging of a UPVC door.
Back to top
phild
PostPosted: Sun Feb 01, 2009 10:11 am    Post subject: Adjust door Reply with quote
some p.v.c doors can be adjusted on the hinges there is somtimes a slot useully to fit an allen key turn these and you should see the door move
if the door has glass in it, it should of been toe and healed wich means it takes the weight of the bottom of the door by using packers at the bottom hinged side and underneath the glass on the hinged side
hopr this helps
Back to top
wildbill
PostPosted: Mon Sep 28, 2009 11:32 am    Post subject: Reply with quote
also on the catchs on the door there are allen key adjustments or if its just the top catch which is out adjust the position of the keep on the door frame
Back to top
aditik
PostPosted: Wed Oct 21, 2009 9:50 am    Post subject: Reply with quote
The most occurring event when uPVC door needs adjustment is that when you go to lift the handle up and it seems "stiff". If this is happening you need to make proper adjustments with your uPVC door or call in an expert.
If you continue to carry on using the lock there is a very good chance the lock will fail and the worse case scenario, it can fail in the locked position when you’re outside. This will mean getting a locksmith to not only get you in but also most likely change the whole locking mechanism, which will be inevitable an expensive affair.
You can adjust the PVC, PVCu, uPVC door by first opening the door and try to lock the door in the open position, if it works fine then the problem is with the keeps and the lock is fine.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Carpentry & Joinery All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
