DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: 5-Lever Mortice Deadlock Stainless Steel 2" / 64mm DIY Doctor: Screwfix: Threaded Coach Bolts A4 Stainless Steel M10 x 25mm Pack of 10 DIY Doctor: Screwfix: Industrial Door Seal Aluminium 1250mm Pack of 2 DIY Doctor: Screwfix: Outdoor Dummy Camera
Share and bookmark DIY Doctor
Driveway over drainige ditch
Post new topic   Reply to topic    Diy Doctor Forum Index -> Concreting, drives, paths & patios
Author Message
keenan
PostPosted: Wed Oct 28, 2009 11:17 am    Post subject: Driveway over drainige ditch Reply with quote
I have a building plot which has a 4ft wide by 4ft deep drainage ditch along the side of the single track road that runs along the side of my building plot.
I need to cross this ditch in order to start work on the plot,but also need to find a permanent way of providing access to the plot for vehicles but without blocking the drainage ditch.
I also have to find a way that allows the water running off my drive which slops upwards from the single track road to enter the drainage ditch before washing accross the single track road.
Regards
Michael
Back to top
acsimpson
PostPosted: Wed Oct 28, 2009 3:01 pm    Post subject: Reply with quote
[quote]...
I need to cross this ditch in order to start work on the plot[/quote]
4ft should be manageable with a running jump, failing that a pair of wellies may see you across safe and dry.
[quote],but also need to find a permanent way of providing access to the plot for vehicles but without blocking the drainage ditch.[/quote]
I'm no expert but you could put a cattle grid in place or build a bridge over it. It's probably cheaper to put some large diameter pipes into the ditch and build up on top of them. Best get some proffesionaly advice before hand though to ensure the result will be strong enough for the vehicles you plan to cross it.
[quote]I also have to find a way that allows the water running off my drive which slops upwards from the single track road to enter the drainage ditch before washing accross the single track road.[/quote]
It should be simple enough to incorporate a drainage channel in your drive which will divert the water into the ditch rather than onto the road.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Concreting, drives, paths & patios All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
