DIY Doctor
Screwfix
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: 12 Piece VDE Tool Kit DIY Doctor: Screwfix: Erbauer Ground HSS drill Bit 2mm DIY Doctor: Screwfix: Universal Rainwater Adaptor DIY Doctor: Screwfix: MK 1G 30mm Moulded Box
Share and bookmark DIY Doctor
Knock down part of internal wall
Post new topic   Reply to topic    Diy Doctor Forum Index -> Brickwork and Blockwork
Author Message
asfred
PostPosted: Wed Oct 28, 2009 12:10 pm    Post subject: Knock down part of internal wall Reply with quote
Hi there, I am new to this forum, though have used a lot of the advice on here to help with renovating my house.
I have an internal wall, on my 1st floor, in a cupboard. I am looking to put in a staircase to the loft space.
The wall runs the same direction as my ceiling joists, so pretty sure it is not load bearing. There is also no wall below it (the stairs are below).
My question is how easily, bearing in mind that you agree it's not load bearing, is it to take out say the top metre or so of this wall?
Would I need to put any structure back in it's place?
Thanks in advance for any advice.
Back to top
acsimpson
PostPosted: Wed Oct 28, 2009 3:04 pm    Post subject: Reply with quote
You also need to bear in mind that something needs to take the load of your staircase. Getting a structural engineer in may seem like a lot of expense but it may save you even more in the long run.
Having said that removing the top of a wall should be fairly easy. How you would go about it would depend on it's structure. And as with a lot of jobs the hard part is getting a decent finish once the jobs done.
Back to top
ironmonkey
PostPosted: Mon Nov 09, 2009 9:09 pm    Post subject: Reply with quote
Also depends what type of construction the wall is.The ceiling joists will need to be strengthened to take the top of the stair case.Fairly straight forward job by the sounds of it.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Brickwork and Blockwork All times are GMT
Jump to:
