DIY Doctor
Victoria Plumb
Victoria Plumb - up to 60% sale now on
Victoria Plumb - Sale now onThe UK's leading online supplier of bathrooms and bathroom accessories are committed to the supply of luxury and top quality products at unbeatable prices. Victoria Plumb also pride themselves on their customer service and ensure that visitors receive all the advice, help and support they will need in order to create the bathroom of their dreams.
Victoria PlumbClick through to the Victoria Plumb website and take advantage of their fantastic sale, with savings of up to 60%. There has never been a better time to replace your bathroom!
Share and bookmark DIY Doctor
Mixer tap problem
Post new topic   Reply to topic    Diy Doctor Forum Index -> Plumbing
Author Message
theloony1
PostPosted: Fri Oct 02, 2009 7:10 pm    Post subject: Mixer tap problem Reply with quote
I originally had single taps and the water seemed to come out fine.
I changed about two years ago to these but never checked what the shower was like.
http://www.argos.co.uk/webapp/wcs/stores/servlet/ProductLargeImagePopup?storeId=10001&jsparm=true&imageName=8320627A65UC256656X.jpg&imageText=
Since then I have had tenants in who have recently moved out and said the only problem was the shower dribbled out.
I was thinking it was just the taps and was going to change to these
[img]http://www.argos.co.uk/webapp/wcs/stores/servlet/ProductLargeImagePopup?storeId=10001&jsparm=true&imageName=108-8320892A67UC332735X.jpg&imageText=[/img]
Will this make any difference???
I no when I bought the first taps it said something about it needing to be 1m away from something???[/url]
Back to top
plumbbob
PostPosted: Sat Oct 03, 2009 9:44 am    Post subject: Reply with quote
I can't see the image you posted, but it is irrelevant as I doubt if any shower that uses the bath taps will work better than the mixer you already have.
The reason is the height of the header tank. For the shower to work satisfactorily, the shower head has to have enough pressure (head). Generally this means the head must be at least 1 metre below the base of the cold water header tank. My guess is your tank is sitting on the joists in the loft or worse, in the airing cupboard??
The only way to solve the problem is to raise the height of the tank, fit a booster pump or (the most common in rental properties) fit an electric shower that uses only the mains cold.
Back to top
mike1984
PostPosted: Thu Oct 29, 2009 10:52 am    Post subject: Reply with quote
If your taps are dribbling then it would be a cartridge issue in which case get onto the manufacturer for a spare part and if possible get some ceramic cartridges as these really stop any leaks or drips and are just a couple of quid.
Back to top
rosebery
PostPosted: Thu Oct 29, 2009 11:56 pm    Post subject: Reply with quote
"If your taps are dribbling then it would be a cartridge issue in which case get onto the manufacturer for a spare part and if possible get some ceramic cartridges as these really stop any leaks or drips and are just a couple of quid."
No Mike its not the tap which is dribbling its the shower because the OP doesn't have enough static head to get a decent flow rate. Plumbob has given the correct answer.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Diy Doctor Forum Index -> Plumbing All times are GMT
Jump to:
