DIY Doctor
Permaroof
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Docka Circular Plate Brushed Chrome & Beech Effect 3 Lamp Spotlight DIY Doctor: Screwfix: Polished Chrome Door Numeral No. 3 - 75mm DIY Doctor: Screwfix: Rod Door Handle Brushed Nickel 160mm DIY Doctor: Screwfix: Forge Steel Portable Bench Vice Swivel Base 3
Share and bookmark DIY Doctor
Roof questions...
Post new topic   Reply to topic    Diy Doctor Forum Index -> Roofing
Author Message
shaunnuahs
PostPosted: Wed Jun 17, 2009 6:48 am    Post subject: Roof questions... Reply with quote
What is the concerte that is on the outside edges below the roof tiles called or what is its term?
When fitting new facia's should this concrete that is about 4 inces in depth going under the tile be removed and replaced with new stuff(its 35 years old) ??
Do you use 3-1 mortar or put sealant stuff in it?
If you replace it is it best to protect by putting those plastic covers you can get over it having replaced it?
Thanks Shaun.
Back to top
youasked
PostPosted: Thu Aug 20, 2009 8:35 am    Post subject: Verge in on roofline. Reply with quote
The pointing at the roof edge is a part of the 'Dry verge' which is the aspestos strip under the edge that lies on top of the bricks to stop wet getting into the brickwork. This only needs pointing if loose and falling out. Removing it will only disturbe the edge tiles and youi will probably find the *battern ends rotten. (*Houses over 30yrs)
If plastic 'dry verge' caps put on correctly, the first two tiles are removed up the whole side, new battern ends added, membrane and then the caps. Most companies however only glue, nail or screw the caps to the existing concrete and a quick cosmetic fix. Prices range from £5 to £15 per cap if a company does them. Aveage 5mtr roof side = 15-16 caps. Not really a DIY job as the ridge can be 9-12 mtrs above ground and most domestic laddders will not reach. I have seen roof battern (2x1 treated), attached along the whole length of the verge, and caps simply screwed to that, though they did not overlap the tiles fully, they were very secure.
Good Luck
Back to top
fastforward
PostPosted: Sat Oct 31, 2009 6:24 am    Post subject: Reply with quote
Hi every one.
I want know from any person that what should do or what type of roofing material I should use which give me all season help. Like, it will give heat in winters and cool rooms in summers. Also it protect my house from rain water and resist the force of water for many years.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Roofing All times are GMT
Jump to:
