| View previous topic :: View next topic |
| Author |
Message |
motoloco
Posted: Tue Oct 20, 2009 9:28 am Post subject: One Cold Radiator |
My heating system works fine, except for one upstairs rad which stays completely cold. The feed pipes to and from it are also cold. I have bled it and there is no air and the pin on the TRV moves freely. I've tried turning all the other rads off to send all of the hot water to the cold rad, but that hasn't made any difference.
I've recently moved into the house and I'd guess the heating system is 15 or so years old. The system comprises 2 rads downstairs and 3 rads plus a heated towel rail upstairs. Any ideas?
Cheers |
| Back to top |
steve the plumber
Posted: Tue Oct 20, 2009 4:22 pm Post subject: |
| Silly question but is it actually connected? |
| Back to top |
motoloco
Posted: Tue Oct 27, 2009 9:23 am Post subject: |
| I think so! The room has a laminate flor, so it's not easy to get the boards up |
| Back to top |
MrsDavey the plumber
Posted: Tue Oct 27, 2009 8:46 pm Post subject: |
| Hi there. Is the locksheild turned on? |
| Back to top |
Posted: Tue Oct 27, 2009 9:03 pm Post subject: |
| is the locksheild turned on? |
| Back to top |
motoloco
Posted: Wed Oct 28, 2009 6:54 pm Post subject: |
Yes the lock shield is open and the rad is full of (cold) water. All the other rads are the same (hot) temp, but this one is cold. |
| Back to top |
Barry Bunsen
Posted: Thu Oct 29, 2009 7:08 pm Post subject: |
You could turn off the two valves and let some water out of the bleed valve to depressure the rad. When you close the bleed valve and re open the valves you could see if it repressurises, using the bleed valve again. The point is it would answer Steves question about whether or not the rad is connected - unless you have a mega blockage.
It would also be interesting to see if you cracked the nuts under the valves whether or not water would flow, but you would have to know what you are doing (turn the boiler off, expect a mess, put the system back to the correct pressure, remove any new airlocks, maybe add some more inhibitor etc)
Good luck. |
| Back to top |
motoloco
Posted: Sun Nov 01, 2009 4:40 pm Post subject: |
Thanks Barry
I've tried what you suggested and the rad fills up again, so there doesn't appear to be a blockage. I guess it's time to call a plumber! |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
