DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Yellow Hose 50m x 19mm (") DIY Doctor: Screwfix: Ogee Fascia Brackets 112mm Pack of 10 DIY Doctor: Screwfix: Fire Alarm Control Panel 2 Zones DIY Doctor: Screwfix: White Gloss Slab Kitchen 600mm Single Built Under Oven App. Unit & Filler
Share and bookmark DIY Doctor
render over dpc
Post new topic   Reply to topic    Diy Doctor Forum Index -> Damp and damp proofing
Author Message
chrisbpt
PostPosted: Sun Nov 01, 2009 5:30 pm    Post subject: render over dpc Reply with quote
Hi All,
I recently bought a new house (built around 1895) and unfortunetly the front room has quite a few damp problems. To cut a long story short the front wall of the house was being effected by rising/penitrating damp.
This seems to have been happening due to two reasons. Firstly the slate DPC had been rendered over. Secondly there has also been some under pinning (probably DIY its also only 1 brick below the DPC) and rain is now bouncing off the concrete slab (underpinning) and in to the render above the DPC.
One other point I should mention is that the wall has also had a chemical DPC injected along the wall two bricks above the slate DPC. This obviously didn't solve the problem.
I am pretty sure that with two DPC's now in place the rising damp issue is now sorted. The penitrating damp from rain bouncing obviously isnt
I obviously can't remove the under pinning to dig a french drain so was wondering what my option are. I think I need some sort of barrier to stop the rain bouncing off the under pinning and in to the wall but am not sure of the different ways that this can be done?
Is there some sort of facia/skirt that can be attached to the bottom of the wall to cover over the DPC's? I was also thinking of running some synthetic DPC up the the brickwork(the dpc would need to lip out between the render above the DPC to stop damp rising through the render) and rendering over it, would that work?
[img]http://www.chrisburrowspersonaltrainer.co.uk/DSCN1365.JPG[/img]
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Damp and damp proofing All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
