DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Halolite Fixed MR16 Polished Chrome Low Voltage Downlight DIY Doctor: Screwfix: Telephone Extension Kit 10m DIY Doctor: Screwfix: Hand Tight Flexible Hose 22mm x 3/4 BSP 500mm Pack of 2 DIY Doctor: Screwfix: Volex 20A DP Sw + Neon Blk Ins Brushed Sless Flat Plate
Share and bookmark DIY Doctor
Removing old stud walls and building new
Post new topic   Reply to topic    Diy Doctor Forum Index -> Plastering & Dry lining
Author Message
jimmyfivebellies
PostPosted: Fri Oct 30, 2009 11:07 pm    Post subject: Removing old stud walls and building new Reply with quote
I live in an 1880's Victorian terrace. The upstairs has 3 mismatching stud walls dividing the landing from bathroom and both first floor bedrooms. The one dividing the landing and the bathroom has been put in very badly. The one dividing the landing from the back bedroom is partially decent with a few warped bits at the edges. The other wall is new but a lot thinner than the others. Is it a big job to rip out all of the walls and rebuild them with uniform thickness/door hole sizes?
Back to top
PostPosted: Sun Nov 01, 2009 7:32 pm    Post subject: Reply with quote
jimmyfivebellies,
Is it a big job to rip out all of the walls and rebuild them with uniform thickness/door hole sizes? - Depends on your viewpoint/capabilities.
You will have to make sure the walls are not supporting anything above - roof structure, water tanks, joins in rafters etc. You will probably also find electric and water services buried in the walls.
If you do remove the existing walls you will have a disposal issue with the plasterboard it has to go to designated dumps. I have not yet found a company which will provide a skip for plaster products.
You could board over the existing walls (with packing as required) and modify the existing openings.
Back to top
rosebery
PostPosted: Sun Nov 01, 2009 8:29 pm    Post subject: Reply with quote
No but just make sure they are studs and not load bearing and make sure they aren't holding the L&P ceiling up!
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Plastering & Dry lining All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
