DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Circular Terminal Box Lid Black DIY Doctor: Screwfix: Forge Steel Heavy Duty Hand Riveter DIY Doctor: Screwfix: Danfoss 102 Mini Programmer DIY Doctor: Screwfix: Masterseal PVC Cable Entry - White
Share and bookmark DIY Doctor
Coombi boiler flow stopcock
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
Author Message
dpicton
PostPosted: Sat Nov 07, 2009 9:43 am    Post subject: Coombi boiler flow stopcock Reply with quote
I wish to drain down the radiator system heated by a combi boiler. I don't see any stop valves next to or near the boiler - should there be one. Would the stop valve on the incoming cold main be the valve to operate before draining the system?
Back to top
rosebery
PostPosted: Sat Nov 07, 2009 11:49 am    Post subject: Reply with quote
Yes.
Back to top
htg engineer
PostPosted: Sat Nov 07, 2009 7:54 pm    Post subject: Reply with quote
You can drain the CH system without isolating any valves, as to refill you would have to use the combi fill.
Closing the MCWS isolation valve will stop the hot water - nothing else.
htg
Back to top
rosebery
PostPosted: Sun Nov 08, 2009 11:50 pm    Post subject: Reply with quote
"Closing the MCWS isolation valve will stop the hot water - nothing else."
It will stop the CH system filling if someone leaves the combi fill valve open at the wrong time though!
Back to top
htg engineer
PostPosted: Mon Nov 09, 2009 7:18 pm    Post subject: Reply with quote
But the cmbi fill should not be connected unless re-pressurising - it's against water regs to leave combi fill connected permanently.
htg
Back to top
rosebery
PostPosted: Mon Nov 09, 2009 7:25 pm    Post subject: Reply with quote
Yes I know that but how many people do? My suggestion of isolating at the stopcock is belt and braces for those that do.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Jump to:
Powered by
phpBB © 2001, 2005 phpBB Group
