spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Ariel Corotherm Fivewall Polycarbonate Sheet Clear 1050 x 25 x 2500mm Pk5 DIY Doctor: Screwfix: Norton Fibre Disc 115 x 1.5 x 22mm 60 Grit Pack of 10 DIY Doctor: Screwfix: Easydrive Black Reverse Thread Drywall 32mm Pk1000 DIY Doctor: Screwfix: Cream Shaker Kitchen 500mm Drawer Line Single Base Unit & Door
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Best location for digital aeriel amp
Post new topic   Reply to topic    Diy Doctor Forum Index -> Home Automation & Cinema
View previous topic :: View next topic
Author Message
armytouch
PostPosted: Sat May 31, 2008 4:56 pm    Post subject: Best location for digital aeriel amp Reply with quote
Hi i have just got a aeriel, a 4 way amp to feed to 3 rooms,where would be the best place to have the amp. I would like the tvs in front room,kitchen and bedroom, dont think will be happy with it in roof space because of disturbing tiles/felt. Please any suggestions,i take it there not waterproof so have to be sited indoors.
Back to top
View user's profile Send private message
plumbbob
PostPosted: Sat May 31, 2008 10:27 pm    Post subject: Reply with quote
The amp should be as near to the aerial as possible to prevent signal degradation. Normally this means fitting in the loft space. This will also allow the easiest cable feed to each tv.
Back to top
Guest
PostPosted: Sun Jun 22, 2008 5:06 pm    Post subject: Reply with quote
Depends on the amp used. The Loft Box uses special wall plates and combines and separates signals allowing Sky, cable, FM, DAB etc all to be re-transmitted throughout the house. In general the closer to aerial the amp is placed the better mast head amps are best normally come in two parts and power supply which injects DC into the coax to feed the amp on the mast. There is so much to consider for example rejection of unwanted signals from taxi, police etc. There is no substitute for a good narrow band aerial where they can be used but freeview often is slotted in and needs a wide band aerial which are much bigger than the narrow band and catch the wind more. So much changes area to area. Winter Hill users for example can use narrow band but Moel-y-parc needs wide band.
All best Eric
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Home Automation & Cinema All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
