spacerspacerspacerspacerAdvertise Here
DIY Doctor
Cadforum
Related Projects: Low drone from flat roof mounted air conditioning unit
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Post new topic   Reply to topic    Diy Doctor Forum Index -> Soundproofing
View previous topic :: View next topic
Author Message
Phil Lucas
PostPosted: Mon Dec 22, 2008 12:56 pm    Post subject: Low drone from flat roof mounted air conditioning unit Reply with quote
I have just installed an air con unit on a flat roof of my house. Construction is fairly basic: bitumen covered ply on 7" wooden joists with 12.5mm plasterboard on the underside of the joists forming the ceiling of the room below. The air con unit is mounted on hard rubber mounts on a metal stand which has four one 8"x8"square pad feet, each foot sitting on a thick solid rubber sole. Inside, we can hear a low frequency drone. I am about to renovate the rooms below, so I would be most grateful if someone would suggest a way of reducing the fan drone noise.
Should I try to decouple the air con unit some more? Perhaps by putting lead sheet or cork board under the feet?
Should I decouple a sound insulation ceiling board from the joists using Z-bars?
Should I put as much dense firbre wool matting between the joists as possible?
Many thanks, Phil
Back to top
View user's profile Send private message
PostPosted: Tue Dec 23, 2008 6:21 pm    Post subject: Reply with quote
Phil Lucas,
Can only suggest you get hold of some 25mm thick foam rubber sheet and some 300mm square paving slabs. Use these to form large bearer for the existing feet.
Back to top
Perry525
PostPosted: Sat Jan 03, 2009 6:35 pm    Post subject: Reply with quote
You need to identify if the sound is airborne or via the fabric of the building.
If airborne and via the windows then secondary glazing will probably solve the problem.
If transmitted via the fabric of the building, then you need to de couple the air conditioner from the roof.
Placing the air conditioner on a tray suspended by several springs from a frame, or spreading the load over a wider area using softer foam rubber will solve the problem.
Back to top
TheDoctor5
Site Admin
PostPosted: Wed Jan 28, 2009 10:27 am    Post subject: Reply with quote
Back to top
Display posts from previous:
Post new topic   Reply to topic    Diy Doctor Forum Index -> Soundproofing All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
