spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Dorma TS68 Overhead Door Closer DIY Doctor: Screwfix: Goldscrew Plus Countersunk 3.5 x 30mm Pack of 200 DIY Doctor: Screwfix: Erbauer Multi Pocket Shorts 34 DIY Doctor: Screwfix: Cream Shaker Kitchen 500mm Drawer Line Single Base Unit & Door
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
scart signal to another room - without wireless??
Post new topic   Reply to topic    Diy Doctor Forum Index -> Home Automation & Cinema
View previous topic :: View next topic
Author Message
prbaxter
PostPosted: Fri Jan 09, 2009 9:49 am    Post subject: scart signal to another room - without wireless?? Reply with quote
Hi all,
I have a wireless TV sender, but it always gives bad reception due to the number of wireless devices that we and our neighbours have in our houses.
So, I'm wanting to fit a scart wall socket in our living room, and have the cable chased in to the wall to the bedroom directly upstairs, where there will be another scart wall socket.
Has anyone done this? are there any limitations such as signal strenth over distance, etc...? and where can I buy the materials? I've found some sockets but not too sure about the cable. Do I just buy a very long scart to scart cable (10m should do it)?
And whilst I'm at it, I might as well install cables for component, HiDef and Coax, so all I have to do is change the face plates if I have the need to change.
Any ideas?
Bax
Back to top
View user's profile Send private message
plumbbob
PostPosted: Sat Jan 10, 2009 11:16 pm    Post subject: Reply with quote
Part of the problem you will have is the number of cables needed for a scart plug. They have 21 wires if all pins are connected. If you use a good quality screened cable normal video and audio signals will carry that distance without noticeable degradation. Different for HDMI though.
If you just need composite video and stereo, then not all the cables will be needed.
Try the web for Maplin they sell scart cable for £1.79/mtr.
Back to top
Guest
PostPosted: Sun Jan 11, 2009 1:43 am    Post subject: Reply with quote
Much depends of quality you require but I got a unit that converts SCART or Com syn into an RF signal like any analogue TV uses. This is in lead from DVD player to down stairs TV.
I also have two satellite receivers one free to air and one sky the RF cable also goes via these too I had to note all channels in use and carefully select free channels but I took cable into loft and through a four way active splitter so all three bedrooms and kitchen have three extra channels as well as normal analogue.
The system seems to work well. There are proprietary systems that do the same thing.
On a 14 inch TV it's OK I would think with a 42 inch TV you would find it lacked quality but I don't use such big TV's in bed room.
I think you will find SCART will not work very well over long distances although I have long S video lead which seems to work OK got it from Aldi
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Home Automation & Cinema All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
