spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: White T & G Cottage Kitchen 1000mm Corner Drawerline Base Unit & Doors DIY Doctor: Screwfix: Universal Wall Mounting Bracket DIY Doctor: Screwfix: JELD-WEN Sliding Oak Double Glazed Timber Patio Door 2394 x 44mm DIY Doctor: Screwfix: Forest Plastic Shed Base Medium Storage
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
vaillant ecotec plus 831
Post new topic   Reply to topic    Diy Doctor Forum Index -> Gas and Gas Fitting
View previous topic :: View next topic
Author Message
stoniemcfc
PostPosted: Wed Sep 30, 2009 6:35 pm    Post subject: vaillant ecotec plus 831 Reply with quote
had this installed 2 years ago and been really pleased with it but even though i have the thermostat in the hall set to summer (5 degrees) the boiler has been firing up and warming the radiators.To temporally solve this problem i have turned the water temperature on the boiler (radiator only) all the way down and this prevents for some reason the boiler firing up.So has anyone ant ideas why the boiler is doing this all of a sudden....thank
Back to top
View user's profile Send private message
DEEARR2
PostPosted: Sat Oct 03, 2009 4:40 pm    Post subject: Reply with quote
First thought would be the room stat being faulty. You could switch off the power to the heating system and disconnect the room stat and so create an open circuit in the boiler contol. Make sure the disconnected cables are separated and made safe. Switch the power on and see if the boiler still fires, if it does then the problem is within the boiler or the wiring between the boiler and the stat.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Gas and Gas Fitting All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
