spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Plastic Line Box 2 Pair DIY Doctor: Screwfix: MK 1G 30mm Moulded Box DIY Doctor: Screwfix: SDS Plus Drill Bit Combi Set 12 Pc DIY Doctor: Screwfix: Wera BiTorsion Stainless Steel Bit Pozi #3 25mm
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Air Coming in Via Vent Pipe
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
Exdaddy
PostPosted: Wed Oct 28, 2009 10:34 pm    Post subject: Air Coming in Via Vent Pipe Reply with quote
At the moment I am still suffering from air in the central heating. (open vented system). I know I have a faulty Actuator as the manual lever moves with no resistance. I am trying to find out why air is continually in the system. I have placed the end of the vent pipe in a small container of water. After a couple of days the level has go down, suggesting it is being sucked into the vent pipe. I can only assume this is how air is constantly coming into the system.
This has happened only over the last few months, system was working fine for years before that. Can anybody advise why this has suddently happened? Would it have something to do with the faulty actuator?
Thanks in advance.
Back to top
View user's profile Send private message
DEEARR2
PostPosted: Thu Oct 29, 2009 8:31 pm    Post subject: Reply with quote
Not knowing it the actuator is driving a 2 or 3 port valve, or how the system is piped, it would be difficult know if it is contributing directly to the air problem. Obviously the first thing to do would have the actuator replaced and see if it as an effect on the air problem. If the problem persists then there are other avenues that can addressed.
Back to top
rosebery
PostPosted: Thu Oct 29, 2009 11:26 pm    Post subject: Reply with quote
Check the pump setting. If its on the highest speed then turn it down to the mid setting. Does that stop it?
If not you may find that fitting a Myson aerjec or similar will fix the problem.
Back to top
Exdaddy
PostPosted: Tue Nov 03, 2009 1:46 pm    Post subject: Faulty Actuator Reply with quote
Thanks for your replies. The actuator/valve is a 3 port mid-position model.
I looked again today and there is also hot water coming into the F&E tank, which I think suggests pumping over?
I tried to replace the actuator today, but it is impossible to reach to unscrew it, from the valve body, due to a poor installation position. I will have to go for the bigger job of replacing the whole valve.
I assume that the faulty actuator is causing the valve ball to be in the wrong position and therefore causing the over pumping - any thoughts?
Back to top
rosebery
PostPosted: Tue Nov 03, 2009 10:14 pm    Post subject: Reply with quote
Please be specific about which vent is pumping over and which is sucking air. From your first post I guesed you meant the vent to the F&E tank but it can't be pumping over and sucking air at one and the same time.
Did you check your pump speed and did altering it have any effect on the air being sucked in?
Back to top
Exdaddy
PostPosted: Thu Nov 05, 2009 9:10 pm    Post subject: Reply with quote
It is the open vent pipe into the F&E tank.
With the pump setting on 2, the air in the system is much worse, with banging pipes and the occasional release of hot water into the F&E tank via the vent pipe. I have been into the loft and watched this happen,
There are odd times when air must have been drawn into the system via the same pipe. Turning the pump up to 3 does reduce this problem, but the pump was always previouswly set on 2.
The pump setting on 3 is a bit noisey.
The 3 port valve actuator is definitely faulty.
Back to top
rosebery
PostPosted: Sat Nov 07, 2009 12:25 am    Post subject: Reply with quote
"It is the open vent pipe into the F&E tank."
Thanks.
"With the pump setting on 2, the air in the system is much worse, with banging pipes and the occasional release of hot water into the F&E tank via the vent pipe. I have been into the loft and watched this happen,"
Your system is "pumping over". Do not leave it as all you are doing is circulating oxygenated water which will cause corrosion in the system apart from filing the syetm with air. Pumping over is a symptom of a problem not the problem itself which could be:
1) An incorrectly placed pump,
2) Pump speed too high
3) Insufficient static head
4) Incorrectly configured system
5) System blockage
This topic has been covered many times before on this forum. Use the search functon and you will find the answers. Here are some threads for example:
http://www.diydoctor.org.uk/forums/viewtopic.php?t=7733
http://www.diydoctor.org.uk/forums/viewtopic.php?t=7738
http://www.diydoctor.org.uk/forums/viewtopic.php?t=7702
"There are odd times when air must have been drawn into the system via the same pipe."
You are guessing. If its pumping over you are circulating oxygenated water in the syetem. Thats where the air is coming from.
"Turning the pump up to 3 does reduce this problem, but the pump was always previouswly set on 2."
I suggested you turn the pump speed DOWN NOT UP. If its normally on 2 what happens on 1?
"The pump setting on 3 is a bit noisey."
Air in it most likely.
"The 3 port valve actuator is definitely faulty."
But thats nothing to do with your pumping over problem. Just because the manual control is a litle bit floppy it doesn't mean the thing is faulty. Its common and it still works. Ifyou have heating when you want it (nothwithstamding your pumping over issue) and hot water when you want it the valve is operating just fine.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
