spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Crabtree 20AX DP Sw with Red Rocker DIY Doctor: Screwfix: Manrose Laminated Aluminium Silver 10m x 315mm Ducting Hose DIY Doctor: Screwfix: Spike Chain 5m x 6mm DIY Doctor: Screwfix: Blank Insert Graphite
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
worchester bosch room stat problem
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
angelpie
PostPosted: Thu Oct 29, 2009 5:56 pm    Post subject: worchester bosch room stat problem Reply with quote
help....., my 4ys old 30cdi keeps losing its transmitter signal, the colon on the reciever flashes and i have to press the ok button to reset the signal. i have rang tech support and they weren't the helpfullest, man suggested to put fresh batterys in which i have done today, and then if not solve the problem to buy new roomstat..is this the case or should i try something else.. many thanks.............
Back to top
View user's profile Send private message
PostPosted: Fri Oct 30, 2009 4:54 pm    Post subject: Reply with quote
Hi, try moving it closer to boiler in case something is interfering with the signal.
Check for any new electronic devices between the boiler & 'stat eg PC, play station, cordless telephone base set etc.
The signal from 'stat is VERY low power and it doesn't take much to 'kill' it.
regards Sparx
Back to top
angelpie
PostPosted: Fri Oct 30, 2009 6:10 pm    Post subject: Reply with quote
thanks for the speedy reply sparx........ i'm going to try that. if that fails is it fair to say that the room stat is faulty??
Thanks again angelpie
Back to top
PostPosted: Sun Nov 01, 2009 1:24 pm    Post subject: Reply with quote
Hi again,
before doing anything drastic if it is a worcester thermostat there is a forum i found by entering Bosch Worcester 30 CDi in google and found 13 bosch engineers on line for questions, might be worth a try.
Normally such things either work or not so assuming good new battery fitted and moving it closer makes no difference must assume faulty.
Not cheap to buy but very easy to DIY replace. receiver slots in with just a low voltage 4 pin plug on short ribbon cable.
regards Sparx
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
