spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Magnetic Cabinet Catches White 65mm Pack of 10 DIY Doctor: Screwfix: InSinkErator Standard Waste Disposal Unit DIY Doctor: Screwfix: DeWalt DT7915-QZ Screwdriver Bit Set 11 Pc DIY Doctor: Screwfix: Fluidmaster Side Entry Fill Valve
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Combi boiler
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
dpicton
PostPosted: Sat Oct 31, 2009 5:48 pm    Post subject: Combi boiler Reply with quote
I wish to insert a new radiator and remove an existing radiator within an 'up and running' heating system that is powered by a combi boiler. I have not dealt with a combi boiler installation before and so am unfamiliar with the system. I am not a plumber but am reasonably competent and am happy about fitting the new and removing the radiators having done this before with non combi boiler installations. My question is, when I refill the system having done the job, how do I re-pressurise the system, what else do I need to do at this final stage? Thank you in anticipation. Don Picton
Back to top
View user's profile Send private message
rosebery
PostPosted: Sun Nov 01, 2009 10:35 am    Post subject: Re: Combi boiler Reply with quote
Its easier than what you did previously. Just release the pressure from the system by draining water off at the drain cock. On the boiler there is a pressure guage. When this drops to zero you can isolate the radiator concerned and make your replacement.
When you have finished then you can repressurise the system using the "filling loop" for the boiler. This will probably be indentifable as a length of flexible braided pipe with one end connected to the boiler and the other to a ballofix service valve. Some boilers have an inbuilt system which is operated by inserting a special key in the base of the boiler. Open the valve and monitor the pressure at the guage. When it reaches iro 1.5 bar shut the valve.
Job done.
Back to top
dpicton
PostPosted: Sun Nov 01, 2009 2:05 pm    Post subject: Re: Combi boiler Reply with quote
[quote="rosebery"]Its easier than what you did previously. Just release the pressure from the system by draining water off at the drain cock. On the boiler there is a pressure guage. When this drops to zero you can isolate the radiator concerned and make your replacement.
Job done.
Cheers[/quote]
Thanks very much for that, DP
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
