spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Purdy Glide Elite synthetic 2 DIY Doctor: Screwfix: Caterpillar Hoodie Black Size XL 46-48 DIY Doctor: Screwfix: Yorkshire Tectite Sprint Male Coupler 15mm x DIY Doctor: Screwfix: Richard Burbidge Fusion Stair Parts White Oak Newell 750mm
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Central Heating circulating through header tank
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
dinoprint
PostPosted: Sun Nov 01, 2009 4:01 pm    Post subject: Central Heating circulating through header tank Reply with quote
When central heating is on water vents through overflow pipe into header tank which does not fill up. Venting stops when pump is turned off. Pump is Grundfoss 15/60 on lowest speed on 22 mm return to boiler. All radiators are hot and there is no air in the system
Back to top
View user's profile Send private message
PostPosted: Sun Nov 01, 2009 7:15 pm    Post subject: Reply with quote
dinoprint,
Increase the height of the top of the overflow pipe.
Back to top
rosebery
PostPosted: Sun Nov 01, 2009 9:00 pm    Post subject: Reply with quote
Your system is "pumping over". Do not leave it as all you are doing is circulating oxygenated water which will cause corrosion in the system. Pumping over is a symptom of a problem not the problem itself which could be:
1) An incorrectly placed pump,
2) Pump speed too high
3) Insufficient static head
4) Incorrectly configured system
5) System blockage
This topic has been covered many times before on this forum. Use the search functon and you will find the answers. Here are some threads for example:
http://www.diydoctor.org.uk/forums/viewtopic.php?t=7733
http://www.diydoctor.org.uk/forums/viewtopic.php?t=7738
http://www.diydoctor.org.uk/forums/viewtopic.php?t=7702
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
