spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Self Drilling Screws with Washer 5.5 x 38mm Pack of 100 DIY Doctor: Screwfix: Mascot Tondela Jacket Size L 41 DIY Doctor: Screwfix: JG Speedfit Straight Tap Connector 15mm x " Pack of 5 DIY Doctor: Screwfix: Replacement Sanitiser
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Central heating works except for one radiator
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
ches501
PostPosted: Sun Nov 01, 2009 6:20 pm    Post subject: Central heating works except for one radiator Reply with quote
As stated in the heading, my central heating system works with the exception of one bedroom radiator. The pipe leading into the radiator feels hot, but the radiator is cold. I have tried bleeding it but there is no air trapped. I have turned the valve on the in pipe but again no change
Any thoughts appreciated
Back to top
View user's profile Send private message
DEEARR2
PostPosted: Sun Nov 01, 2009 9:29 pm    Post subject: Reply with quote
Have you tried turning off all other radiators via their local valves leaving this one open. If this shows an improvement then your system needs balanced in favour of this radiator.
Back to top
rosebery
PostPosted: Sun Nov 01, 2009 10:31 pm    Post subject: Reply with quote
If its a TRV on the flow remove the head completely so that the valve springs fully open. With the head off press down on the centre of the valve to make sure it is operating. They do get stuck. If its stuck shut then it will not allow any hot water into the rad - hence cold rad. Wiggle it up and down against the spring to free it up. If its totally seized then you are probably looking at replacing it.
Also have you checked that the lock shield valve (ie the return) is open?
If the TRV is operating properly and the LS valve is open then its possible that the rad may be well sludged up. In which case isolate it, take it off the wall out into the garden and flush it through with mains pressure water. Then rehang and try again.
However there is also another possibility. With the heating running and hot let more than just a dribble out of the bleed valve so that you persuade the rad to fill with hot water and see if that gets a flow going. It will probably take the best part of a bucket load so make sure that your F&E tank is functioning properly if you have one or that there is someone on hand to top up the pressure at your combi if thats what you have.
HTH
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
