spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Flowflex Chrome Elbow 15mm DIY Doctor: Screwfix: Ronseal 5Yr Woodstain Satin Antique Pine DIY Doctor: Screwfix: TurboGold Selection Pack DIY Doctor: Screwfix: Beech Style Kitchen Bridging Door for 600mm Bridging Unit
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
No pressure in rads...
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
notgnirraw
PostPosted: Mon Nov 02, 2009 6:57 pm    Post subject: No pressure in rads... Reply with quote
Dont know much about heating.... have just had the system flushed properly and all was fine. Now I dont have heat upstairs. I have tried to close all downstairs rads to see if that forces pressure up. I am getting slight heat in the 1st rad but nothing else. I have then bled all rads. Lots and lots of air in the upstairs rads but now it wont release. I.e. still air in them but even with bleed valve removed I get no water??
Any ideas?
Back to top
View user's profile Send private message
rosebery
PostPosted: Mon Nov 02, 2009 9:40 pm    Post subject: Reply with quote
What does "just" mean. In last few days / weeks / months? There may be a case for getting the guy back who did it to sort this problem out for you at no cost to you.
Combi boiler? If so system not repressurised OR you are losing pressure due to a leak. Look at your combi. There will be a pressure guage. If its reading less than 1.5 bar then you need to top up the pressure.
You will either have a built in filling loop controlled by a special key that fits in the base of the boiler or an external loop. If the latter you can identify it as a length of braided flexible ipie one end (inevitably) connect to the boiler and the other to a ballofix service valve. Shut all bleed vents you have opened and opetrate the filling the valve. When the pressure reaches 1.5 bar shut the valve and go round in turn opening up the bleed valves so the rads fill with water. You will need to keep topping up the pressure from time to time until all rads are filled and the pressure is steady at iro 1.5 bar.
The run the system and monitor the pressure reading. Make sure the filliling loop valve is completely shut when you have finished or you wil overpressurise the system.
HTH
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
