spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Bosch GKS18V 160mm Circular Saw DIY Doctor: Screwfix: Pull Handle Satin Aluminium 425mm Pack of 2 DIY Doctor: Screwfix: MK 1G 16mm Moulded Box DIY Doctor: Screwfix: Galvanised Straight Brads 18ga 25mm Pack of 2000
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Noisy central heating
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
scroogemonster
PostPosted: Mon Nov 02, 2009 6:57 pm    Post subject: Noisy central heating Reply with quote
Our central heating system is just over 1 year old.
When the heating has been on for some time the radiator valves make a hissing noise (like water coming to the boil in a kettle.) If I turn down the TRV the noise stops but appears again if I turn them back up.
How can I fix this? It happens on several TRV's but not all.
Thanks in advance
Kevin :? :?
Back to top
View user's profile Send private message
rosebery
PostPosted: Mon Nov 02, 2009 9:56 pm    Post subject: Reply with quote
Is the boiler stat turned up too high? Is the boiler itself kettling or just the TRVs making funny noises?
Turning the TRV down just closes the valve. Each TRV should have an arrow on the body indicating the recommended direction of flow. Are they fitted the wrong way round? Modern good quality TRVs such as Danfoss, Pegler, Honeywell etc are bi-directional and quiet. If yours are a cheap and cheerful make then they may not be bi-directional or quiet.
Is it a combi boiler? If so what is the pressure reading on the gauge? If its more than iro 1.5 bar when the system is hot then you need to let some water out to reduce the pressure.
Did your installer fit an autobypass valve?
Back to top
scroogemonster
PostPosted: Tue Nov 03, 2009 9:43 pm    Post subject: Reply with quote
Thanks for the reply.
The radiator dial on boiler is set to max. It's just the trv's hissing prior to them shutting off when the required room temp is reached, the boiler itself is very quiet.
My trv's are Pegler bulldog and are bi-directional I think (two arrows on the stem?) The Boiler is a Worcester Bosch 30cdi. The pressure gauge reads 1 bar when not operating and aroung 1.5 bar when the system is running.
I have replaced the head on the noisiest one with a Drayton trv, seems much quieter.
Any further ideas?
Kevin
Back to top
scroogemonster
PostPosted: Tue Nov 03, 2009 9:45 pm    Post subject: Reply with quote
I have replaced the head on the noisiest one with a Drayton trv, seems much quieter. I have no idea if the installer fitted an auto bypass valve (where would it be?)
Any further ideas?
Kevin
Back to top
rosebery
PostPosted: Wed Nov 04, 2009 12:34 am    Post subject: Reply with quote
OK thanks for reply which helps.
Where is the roomstat fitted? I'm guess in the hall - thats normal. In that case the rad in the hall will (or should) NOT be fitted with a TRV. There are two reasons for this:
1. The rad acts as a crude bypass.
2. The TRV would close when the room reaches the required temp by the TRV. But if the roomstat is set to a higher temp then it will continue to call for heat but it will never get hotter because the TRV is keeping the temp down. So all you do is burn gas for no effect.
When he did the install he should have balanced the system. Take note of the exact number of turns (to the nearest 1/4 turn) that the lock shield valve is set tp from its current position to fully open. With both valves fully open does the noise stop?
An autobypass valve looks like this:
http://www.awin1.com/awclick.php?mid=1228&id=61071&p=http://www.screwfix.com/app/sfd/cat/lrgimg_popup.jsp;jsessionid=PPJWTGH0N53G4CSTHZOSFFQ?productId=34127&imageNo=null&ts=93012
BUT your boiler may have got an inbuilt bypass. Data should be in the Manufacturers Instructions and the installer should have adjusted it for the best setup.
Just noticed that you said the installation is only a year old - sorry should have spotted that. In that case I think you should give your installer a call as its likely that the remedy lies in his hands.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
