spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Stabila 70-2 Series Spirit Level Set 3Pcs DIY Doctor: Screwfix: Quickfix Fixings Kit DIY Doctor: Screwfix: Symmetric 42W Black Floodlight DIY Doctor: Screwfix: Trend 2 Flute Straight Cutter 1/2" 15x25mm
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Roaring noise from behind my chimney
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
wolfie882
PostPosted: Mon Nov 02, 2009 7:07 pm    Post subject: Roaring noise from behind my chimney Reply with quote
A newbie’s first post….!
Don’t know if anyone out there can shed any light on a strange “problem” I have.
My central heating system is pretty straightforward - I have a Baxi Bermuda back boiler behind a Baxi fire. Over the last few months I have heard an unusual “roaring” noise coming from the chimney breast area above the fire. Put my ear to the chimney breast at head height and it sounds a bit like a kettle is boiling inside the chimney. Lower down by the fire the sound still there but is less apparent. The fire is off during this time. The system timer clock is off.
It only ever happens early in the morning (6 - 8 am) and each time the noise appears approx once an hour and only lasts about 10 minutes before fading away.
I have had the Baxi serviced, and had a drop test done for leaks, and the bottom of the flue checked and everything is in order. The engineer who serviced the boiler says that from what we describe it sounds like the boiler is firing. Don’t think that is the case because there is definitely no burner flames visible underneath the boiler, and the roaring sound does not appear to be emanating from behind the fire and it is not quite the same sound as when we switch the boiler on.
This morning I experimented and turned the gas supply off at the mains and……………….no roaring sound!
It’s a real mystery!
Back to top
View user's profile Send private message
rosebery
PostPosted: Mon Nov 02, 2009 9:45 pm    Post subject: Reply with quote
Been doing it a long time or just since the service? If the latter get 'em back to do a better job of sorting it out.
Alternatively just turn up the volume on the TV (joke OK?)
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
