spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: CANNED SMOKE DIY Doctor: Screwfix: Health & Safety Law Poster DIY Doctor: Screwfix: 2 x 36W Opal Diffuser Batten Accessory Pack of 4 DIY Doctor: Screwfix: Ryobi EJS-710QEO 240V 710W Jigsaw
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Leaking 10mm manifold
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
buzzbomb
PostPosted: Tue Nov 03, 2009 7:52 pm    Post subject: Leaking 10mm manifold Reply with quote
When moving my bathroom radiator I had to reposition some of the 10mm copper pipes under the floorboards. Although I was very careful when repostioning the pipes I noticed a slight wetness at one of the manifold soldered joints. (a 22 x 2 10mmx22 soldered fitting) The pressure is still off the system at present so it is hardly noticable. Reluctant to put the water back on until I try and fix it.Can anyone offer some suggestions on the best way to fix this. ie solder in situ , poxy putty etc. :(
Back to top
View user's profile Send private message
rosebery
PostPosted: Wed Nov 04, 2009 12:46 am    Post subject: Reply with quote
Soldering wet pipe is a no no. It just won't work and you cannot guarantee you can get the joint dry in situ. Best to remove the offending joint completely and solder in a new one. That may mean, in your case, replacing the manifold by the sound of it.
Back to top
buzzbomb
PostPosted: Wed Nov 04, 2009 10:20 pm    Post subject: Reply with quote
thnks for the reply Rosebery. Think I realised this was correct option but the thought of desoldering 2x22m joints and 2 10mm joints in a confined space is not really too appealing. Was wondering if anyone has tried something like Locite repair express putty given it is a new leak and probably not too big. ?
Back to top
acsimpson
PostPosted: Thu Nov 05, 2009 3:09 pm    Post subject: Reply with quote
I have tried using the putty with mixed results, although it is as far as I'm aware only ever meant to be a temporary repair. It cannot hold high pressue (ie didn't work on my weeping joint at mains pressue) and isn't great if the joint is wet at the time you apply it.
If you want sound advice I would listen to roseberry. If you want to bodge it and hope for the best then on your own head be it.
Back to top
buzzbomb
PostPosted: Thu Nov 12, 2009 10:09 pm    Post subject: Reply with quote
thanks for the replies guys. Got a friend to help and we drained the system and ran some solder round the joint and thankfully it worked ok. :D :D :D
Once again thanks for the input
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
