spacerspacerspacerspacerAdvertise Here
DIY Doctor
neweysonline.co.uk - The newest tool of the trade
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Crabtree Pull Switch Brass 50A DIY Doctor: Screwfix: Volex 10A Fan Isolating Sw Blk Ins BN Round Edge DIY Doctor: Screwfix: Cable Clips Double Grey For Twin & Earth Cable 1.5mm Pack of 100 DIY Doctor: Screwfix: Adjustable Brushed Chrome Low Energy Downlight Pack of 3
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Wiring for outside lights
Post new topic   Reply to topic    Diy Doctor Forum Index -> Electrics
View previous topic :: View next topic
Author Message
bristol
PostPosted: Wed Nov 04, 2009 12:55 pm    Post subject: Wiring for outside lights Reply with quote
Hi there
First post so be gentle with me!
Our modern house has two external lights - one by the front door, the other by the garage.
The light by the front door is controlled by a switch in the hall, which the previous owner replaced with a central heaing control, simply so he could use the timer.
I have taken this off, and see two cables, each with red live wires, black neutral and yellow/green earth which are fixed in the earth terminal of the box.
I bought a 6AX intermediate switch (maybe wrongly) and wired up per diagrams - each red and black cable in individual holes (L1-L4)
Having done that the outside light is on permanently.
I didn't know at the time, but I beleive that the two sets of wires relate to each outside light, as I noticed the sensor controlled garage light came on at the same time.
Any thoughts please? - have I perhaps bought the wrong lightswitch?
The controller I removed had the 2 neutrals together but the lights tripped when I tried that.
Back to top
View user's profile Send private message
chriscba
PostPosted: Wed Nov 04, 2009 8:10 pm    Post subject: Reply with quote
The 2 lights are proberly wired in series, & you have got the wrong switch, you proberly need a 1 gang, 1 way switch, the 2 blacks most proberly are neutrals, connect into a block, not in to switch, the 2 reds live feed in & feed out, connect one to top connection & other to bottom, green/yellow earth (cpc) connect to metal box, if not, put in own block.
If the light swich is working upsidedown, swap red wires, or just turn switch around.
Back to top
bristol
PostPosted: Thu Nov 05, 2009 10:54 am    Post subject: Reply with quote
Chris
Many thanks -top man - simply needed to put the neutrals together in a block instead of in the switch.
I have used the same switch though for the two live wires and it all seems to be working fine.
Any safety reasons why I shouldn't keep using the intermediate switch ?
Once again, thanks!
Back to top
chriscba
PostPosted: Thu Nov 05, 2009 6:09 pm    Post subject: Reply with quote
Its perfectly safe to use that switch, it is meant to go in the middle of two way lighting, eg. in the middle of a flight of stairs.
Back to top
bristol
PostPosted: Fri Nov 06, 2009 9:18 am    Post subject: Reply with quote
Thanks mate
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Electrics All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
