spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Halolite Adjustable GZ/GU10 White Mains Voltage Downlight DIY Doctor: Screwfix: Croydex Hampstead Towel Ring Half Chrome DIY Doctor: Screwfix: Stabila 80A Spirit Level 915mm DIY Doctor: Screwfix: CC6 Cable Cleats 15.2mm Pack of 50
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
No power to pump
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
sshaw101
PostPosted: Wed Nov 04, 2009 5:09 pm    Post subject: No power to pump Reply with quote
I have just changed the pump to our central heating system, thinking that this was the reason why we were not getting any hot water or heating. I was wrong.
The boiler fires up and stays lit for a few minutes then as the pump is not circulating the water it switches off. However the pump does not start. The guy who chnaged it said it appears that no power is going to the pump. We dont think it is the motorised switch valves as neither hot water or heating works.
Any ideas?
Thanks in advance
Back to top
View user's profile Send private message
plumbbob
PostPosted: Thu Nov 05, 2009 9:04 pm    Post subject: Reply with quote
The motorised valve controls the pump so if it is faulty then the pump won't work at all.
Because you have not described your system in any detail it is not possible to be more precise! After all, I cannot simply guess?
Back to top
PostPosted: Fri Nov 06, 2009 2:40 pm    Post subject: Reply with quote
Hi, although the valve output controls the pump it normally does so via the boiler since most boilers require the pump to 'run-on' after boiler shuts off, similar to fan in WC running on after light turned off.
So problem may originate at boiler control board.
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
