spacerspacerspacerspacerAdvertise Here
DIY Doctor
Top Tools
Power tools and Hand tools you will need for DIY or Building projects.
DIY Doctor: Screwfix: Ratchet Strap & Hook 6m x 35mm DIY Doctor: Screwfix: Finnlife Jarvi Log Cabin DIY Doctor: Screwfix: Wylex 20A Triple Pole Type C MCB 10kA DIY Doctor: Screwfix: Volex 1G 1W 400W Touch Remote Dimmer BB Flt Plt
Are you a tradesman ? Get your very own webpage with ProblemSolved all for FREE - Click here
Check the DIY Projects pages for your answers before posting your questions..They come with pictures !!
Share and bookmark DIY Doctor
Link to DIY Doctor - Click Here RSS news feed DIY Doctor RSS Feed  Email Bookmark and Share
Hot water but no heating
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation
View previous topic :: View next topic
Author Message
bward
PostPosted: Thu Nov 05, 2009 12:12 am    Post subject: Hot water but no heating Reply with quote
I have just moved into a property with water cylinder and boiler (i.e. not a combination boiler). Using the controls I can only get hot water but no central heating. If I put the heating system to central heating only the three-port valve does not move over to switch the water flow. If I manually change the three-port valve (Honeywell) I can get central heating, but only if I set the controls to hot water only. If I set the controls to central heating only I get nothing, even when I turn the valve manually. Does anybody know if this is likely to be a faulty valve or is it possible that the timer / control unit has gone? Also, is this something I can fix myself or is it a job for an engineer?
Thanks very much.
Back to top
View user's profile Send private message
PostPosted: Fri Nov 06, 2009 8:49 pm    Post subject: Reply with quote
More than likely it'll be the actuator/motorised head.
Buy the same model, swap over one wire at a time. Shouldn't cause you any problems.
ISOLATE ELECTRICITY SUPPLY
Htg
Back to top
Display posts from previous:
Top Tools
Post new topic   Reply to topic    Diy Doctor Forum Index -> Central Heating & Air conditioning & Ventilation All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by
phpBB © 2001, 2005 phpBB Group
