water but no heating
yakadoozy
by yakadoozy » Wed Dec 19, 2007 5:53 pm
hi we had to remove a radiator in the bathroom had it disconected a few weeks ago but when it came to draining the system and removing the pipes i now have no heating! hot water is fine boiler is a baxi bermuda 551
any advise would be most welcome as we are bloomin cold..
marrtin
by marrtin » Thu Dec 20, 2007 1:36 pm
Will everybody please note. If you need advice on a topic please include as much information as possible about your installation otherwise it is impossible to offer much help at all.
by htg engineer » Thu Dec 20, 2007 4:58 pm
The system is airlocked, try draining and refilling again. If this doesn't work, take off a radiator and connect a hose to the rad valves, drain it until you get hot water at flow and return - you'll probably hear when the air escapes.
Baxi bermuda 551's are failry old so I guess it's not a fully pumped system.
