Water hammer when diverter valve closes
Postby Spreadsheetpete » Tue Nov 13, 2007 11:08 am
About 12 months ago I fitted a new central heating system with a Vaillant Ecotec System Boiler, but standard Honeywell Y Plan Controls. Throughout the year a water hammer noise has become increasingly loud and frequent when the diverter valve closes one or other of the ports. I fitted an old Drayton valve which cured the problem but it 'let by' so I have now fitted a new Honeywell 4073 which has caused the return of the problem, although not as bad as it was. We've tried reducing the boiler bypass setting but it made no difference. I'm about to try fitting a shock arrestor but feel that this will mask the problem rather than cure it. Has anyone had a similar experience? (My Corgi registered gas fitter has not come across the problem before).
Spreadsheetpete
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby The Heating Doctor » Tue Nov 13, 2007 9:21 pm
The by-pass is it an automatic one that's fitted out with the boiler?
The Heating Doctor
Rank: Foreman
4.7%
Postby Spreadsheetpete » Wed Nov 14, 2007 8:53 am
[quote="The Heating Doctor"]The by-pass is it an automatic one that's fitted out with the boiler?[/quote]
Yes, the bypass is integral to the boiler.
Spreadsheetpete
Rank: Labourer
50%
Postby The Heating Doctor » Fri Nov 16, 2007 10:48 pm
That is the boiler by-pass and not the system by-pass, I would suggest that you fit an external automatic by-pass, approx £25. This should be fitted between the boiler flow & return within approx 1m of the boiler
The Heating Doctor
Rank: Foreman
4.7%
Postby Spreadsheetpete » Sun Nov 18, 2007 8:13 am
Many thanks for that - I'll have a go at fitting a bypass next week. Fingers crossed!
Spreadsheetpete
Rank: Labourer
50%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
