What are the Building Regulations re: sealing fire doorways?
Postby Mattski » Mon Jan 28, 2008 8:15 pm
I am planning to seal a doorway leading from my Kitchen on the ground floor of my 3 storey townhouse which leads out onto a hallway. Off the Hallway come the stairs to the 1st floor landing and then off this are the stairs to the 2nd floor landing.
I have 3 questions I would like some advice on.
1. What are the Building Regulations re: sealing fire doorways?
2. The remaining doorway out of the Kitchen (which is currently not a fire door) leads into a Dining Room which still has a fire door leading onto the Hallway. Do I need to upgrade the Kitchen to Dining Room door to a fire door or is the existing one enough?
3. Will I need to inform my local Buildings Control Department and will I need Planning permission?
Would greatly appreciate your advice.
Mattski
Rank: Labourer
Progress to next rank:
75%
Sponsor
DIY asbestos test kits
Postby arbco » Tue Jan 29, 2008 7:35 pm
1. As long as the sealing achieves 30 minutes fire resistance then you will be OK. 2 layers 12.5mm plasterboard either side of a 100mm * 50mm stud.
2. No one door is enough.
3. Strictly speaking it is a material alteratin and requirs permission but you wil be OK.
arbco
Rank: Ganger
8%
Postby Mattski » Wed Jan 30, 2008 8:04 pm
Ok, thanks arbco appreciate your advice.
Mattski
Rank: Labourer
75%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
