What is the best electric heating option??? Help!
Postby franceswilliamson » Mon Jan 26, 2009 1:56 pm
Hi, I am so confused. :?
I have a small-ish 2 bed, 1st floor flat which only has electricity, no gas. My storage heaters all need replaced and i was wondering what they best thing to replace them with is. More horrid, useless storage heaters? oil filled thingies? air-con/heat???
everyone i ask has a different opinion, someone even suggested getting gas fittted...
I don't want to spend £££...
anyway, if you have any ideas to throw into the pot i'd be v grateful.
franceswilliamson
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby sparx » Mon Jan 26, 2009 10:05 pm
Hi, it depends on when you are home, if out during most of day then nitestors are not much use since they have given out most of their heat while you are out. In this case why not replace them with convector heaters, get ones with inbuilt thermostats and timers.
If you get the nightstorage fuse board connected to normal supply you can have the same points as before so no extra wiring required, it should not cost much to get tails altered by local leckie.
regards SPARX
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
