Will b. regs apply when converting a bedroom to a bathroom?
Postby andymancan » Fri Oct 19, 2007 7:56 pm
I am converting a box room into a new bathroom, which has been ok'd by my building regs lady. I will be fitting new safety electrics for a whirlpool bath, LED mist free mirror, and dual heated (plumbed and electric element) towel rad. Will the new B. regs apply with regards to getting the job signed off by a qualified electrician? This is an existing room in my existing house,(not my new extension)And what, if any, guidlines should I be following for this job please. Thanks in advance Andymancan
andymancan
Rank: Labourer
Progress to next rank:
50%
Sponsor
DIY asbestos test kits
Postby kbrownie » Sat Oct 20, 2007 8:14 am
Hi andymancan,
The regulation is Part P that would be your main concern regarding the electrical installation. I don't know how experienced you are with electrical installation. I'd recomend you get a Part P quailfied sparky in, it's a legal document.
I believe you can put what's called a "notification order" in to the council and do the work yourself. They will check first/second fix and testing. They do charge for this!
The guildlines mainly concern the installation of Protective conductors, earth/cross bonding, RCDs. Correct application to Zones.
Hope info helpfull
KB
kbrownie
Rank: Project Manager
Postby rosebery » Fri Oct 26, 2007 10:28 pm
Blg Control cannot give you the certificates that a Part P electrician can. Also thePart P qualified sparks should not be signing off someone eses work. He can only give a cert for his own work or someone working under his direct supevision.
And athough your question was specifically related to electrics:
Don't forget that you'll also need to comply with blg regs in relation to notches and holes in joists for pipework and cabling.
Also, you've water regs to consider in relation to your plumbing.
rosebery
Postby philipam » Thu Nov 08, 2007 10:08 pm
[quote="rosebery"]Blg Control cannot give you the certificates that a Part P electrician can. Also thePart P qualified sparks should not be signing off someone eses work. He can only give a cert for his own work or someone working under his direct supevision.
Cheers[/quote]
What water regs in relation to plumbing???????
philipam
Rank: Apprentice
0%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
