Price Doctor - Extension quote and price checking software
The Southern Homebuilding and Renovating Show 2013, Sandown Park, Surrey
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Central Heating & Air conditioning & Ventilation
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Recommend This Page
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    Worcester 24CDi RSF boiler
    Post a reply
    5 posts • Page 1 of 1
    Postby littletoe46 » Sat Oct 06, 2012 7:26 pm
    A most peculiar fault with CH : can anyone help? Boiler is about 6 years old and in VGC
    DHW works perfectly. CH operating pressure about 1.75 bar. PROBLEM ... CH comes on and reaches set temp. Gas goes off, pump etc continues to run. As rads cool the gas will not fire up again, even if rads become cold, or the CH stat is turned up. If ANYTHING is done that will fire up the burner again e.g open DHW hot tap / re-set CH timer / turn boiler off then on again/ or (works sometimes)press re-set button. The CH warms up again and the cycle repeats itself.
    New thermistor fitted on last service quite recently. My service engineer is baffled and suggested calling in Worcester, but this is an expensive option.
    littletoe46
    Top
    Re: Worcester 24CDi RSF boiler
    Postby Atticus Finch » Sun Oct 07, 2012 4:01 pm
    What is each light doing when the fault occurs? on or off or flashing - slow/fast?
    Atticus Finch
    Top
    Postby littletoe46 » Tue Oct 09, 2012 9:06 pm
    None of the fault lights are coming on at all. I've checked the manual against possible faults, but this one is not covered.The only lights that come on is the Burner On light when the boiler is running, and the CH On light.( and the DHW light when required) Naturally the Burner On light goes Off when set temp is achieved. Burner stays off when CH temp reached, CH On light stays on. The Burner on light only comes on again if anything at all is done to re-set boiler or DHW is turned on. Once Burner On is re-established, the gas stays on with the CH until set temp is reached again. If nothing is done to Re-set burner on, it stays off and rads gradually get cold.
    littletoe46
    Top
    Postby Atticus Finch » Wed Oct 10, 2012 10:01 am
    So when the fault occurs the green light is ON, but all red lights are OFF?
    Atticus Finch
    Top
    Postby htg engineer » Tue Oct 16, 2012 5:08 pm
    Probably a faulty sensor/thermistor, it may be a sensor/thermistor with alot of furring/limescale, this will cause the heat to be maintained and this wont allow the boiler to fire up again. You need a multimeter to check the sensors - or just replace them as they're probably the cheapest part that could be at fault.
    Top
    Post a reply
    Return to Central Heating & Air conditioning & Ventilation
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • worcester 24cdi
      by mustang » Sat Mar 17, 2007 6:46 pm
      Last post by KEVANS02 View the latest post
      Thu Mar 22, 2007 9:24 pm
    • worcester 24cdi hot water problem
      by topdec » Wed Nov 26, 2008 5:43 pm
      Last post by topdec View the latest post
    • hot water problem worcester 24cdi rsf
      by bashlo » Sat Jan 09, 2010 7:49 pm
      Last post by bashlo View the latest post
      Sun Jan 17, 2010 4:56 pm
    • WORCESTER 24cdi combi intermittent problem
      by warehouseman » Mon Aug 09, 2010 6:52 pm
      Last post by htg engineer View the latest post
      Tue Aug 31, 2010 7:54 pm
    • worcester 24CDi - problem with hot water supply.
      by colcurly » Wed Feb 16, 2011 11:30 pm
      Fri Feb 18, 2011 8:56 pm
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB® Forum Software © phpBB Group
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
