Worcester Bosh Junior 28i boiler
Postby darrenlass » Sat Jul 17, 2010 8:40 am
Hi there - could anyone help me with some easy/simplified user instructions for above boiler that we have had installed recently. My hubby and I have the user manual but we must be thick as we cant understand them lol! Just wondered if anyone could give us some easy to understand info re how to set the timer/temperature etc? Thanks alot x
darrenlass
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby eggers » Fri Jul 23, 2010 5:12 pm
good luck! worcester and vaillant boilers are extremely over complicated! i bet you got the model with the party mode and the winter mode and sumer mode etc! I'm an engineer and sometimes i can't understand them either!
Do you have the programmer built into the boiler? or is it a wireless system with the mechanical clock and 2 thermostats?
eggers
Rank: Ganger
31.3%
Postby darrenlass » Sun Jul 25, 2010 10:11 am
HI EGGERS, THANKS FOR THE REPLY!. WE HAVE A DIGISTAT ON THE WALL WHICH WE ARE HAVING TROUBLE WITH UNDERSTANDING HOW TO SET? NOT TOO URGENT TO SORT OUT NOW AS WE HAVENT HAD THE HEATING ON DUE TO THE WARM WEATHER. BUT NEED TO 'SUSS' IT OUT BEFORE THE COLD WEATHER APPROACHES.
darrenlass
Rank: Labourer
25%
Postby eggers » Mon Jul 26, 2010 8:45 pm
Square thermostat with larger temp display and underneath is time, to the right is either a 1 in a circle, a 2 in a circle a sun or a moon?
plus button, temp up,
minus button temp down,
select button 1, 2, sun, moon
-1 is timed on
-2 is timed off
-sun is on constant
-moon is off constant
set button sets time for clock, again to set times for heating, plus & minus buttons alter time up and down
eggers
Rank: Ganger
31.3%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
