worcester highflow 400 rads on when off!
Postby CATERTECH » Wed Jun 06, 2007 9:34 am
worcester bosch highflow 400 problem with radiators being on intermittently even when radiator thermostat is turned completely off! also hot water not as fast as it used to be,could it be heat exchanger and if so what is the best way to descale it? anyones help would be appreciated thanks.
CATERTECH
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby toneyt » Thu Jun 28, 2007 5:25 pm
sounds like a blockage in the domestic heat exchanger,tricky job to do but there are other possible causes such as the diverter valv or the non return valve on the central heating flow and return pipes,
it is most likely to be the heat exchanger as this can block and the heated water will try another path of circulation.
do you plan to try this yourself?
toneyt
Rank: Tradesman
65.4%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
cron
