Price Doctor - Extension quote and price checking software
Save up to 50 percent off subcriptions to some of the best DIY and Home Improvement magazines
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Central Heating & Air conditioning & Ventilation
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Recommend This Page
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    worster boiler
    Post a reply
    5 posts • Page 1 of 1
    worster boiler
    Postby tidy » Mon Jul 23, 2012 11:59 pm
    have a worcester boiler .
    problem is hot taps on all sinks work fine but the shower runs hot when adding a bit of cold to get temperature right for having a shower the boiler cuts out and starts running cold.i have two showers in the property and both do the same. what do you think is wrong. any help.
    tidy
    Top
    Re: worster boiler
    Postby Atticus Finch » Tue Jul 24, 2012 11:48 am
    Is it a combi (instant hot water) boiler?
    If so, what happens when you turn a cold tap on at the sink at the same time as the hot tap?
    Atticus Finch
    Top
    Re: worster boiler
    Postby plastic_man77 » Tue Jul 24, 2012 1:30 pm
    @ tidy
    I'm assuming your boiler is a combi and that you are running a shower fed directly from the mains and boiler.
    Sounds like a water pressure problem to me or possibly blocked inlet filters at the showers or boiler.
    If you turn a hot tap on at a sink/basin and then turn the cold tap on at the same time, does the hot flow, slow dramatically? If it does, then you have low water pressure or the stop tap has been restricted for instance, giving a low flow volume- have you done any work lately requiring you to mess with the stop tap?
    Failing it being a pressure problem, I'd check the water filters at the boiler/inlet to the shower.
    plastic_man77
    Top
    Re: worster boiler
    Postby tidy » Tue Jul 24, 2012 6:26 pm
    has been ok for about 7years now but just started to get this problem.
    this inlet filter on boiler .do you mean the heat exchanger. as a friend did say it might be that.
    if so would this not make the hot taps the same as the shower.
    tidy
    Top
    Re: worster boiler
    Postby htg engineer » Sat Aug 11, 2012 7:46 am
    I'm guessing that as you mention it cuts out when the cold water is used, that it is fine if just the hot water is used. It's probably a stretched or split diaphragm in the diverter, when another outlet is used there's not enough water flow to lift the diaphragm. Especially given the age of the boiler, what model Worcester?
    Top
    Post a reply
    Return to Central Heating & Air conditioning & Ventilation
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • Combi boiler pressure loss - pipes or boiler?
      by cpa1104 » Sun Jul 29, 2007 6:50 pm
      Last post by mutti uk View the latest post
      Tue Oct 23, 2007 4:45 pm
    • back boiler to combi boiler dhw connections
      by zebb » Sat Jul 26, 2008 9:22 am
      Last post by zebb View the latest post
      Tue Oct 21, 2008 9:25 pm
    • Combi Boiler and Conventional Boiler in series
      by sky_blue_kev » Tue May 19, 2009 6:41 pm
      Last post by plumbbob View the latest post
      Wed May 27, 2009 5:43 pm
    • Oil fired boiler vs Electric boiler
      by smoki1969 » Tue Jun 03, 2008 4:45 pm
      Last post by htg engineer View the latest post
      Tue Jun 10, 2008 7:19 pm
    • combination boiler / back boiler
      by humble » Sun Nov 23, 2008 10:03 am
      Sun Nov 23, 2008 8:27 pm
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB® Forum Software © phpBB Group
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
