| View previous topic :: View next topic |
| Author |
Message |
marcus thomson
Posted: Thu Apr 10, 2008 12:29 pm Post subject: clio bad starter |
| my girlfriend has a clio 1.2 sometimes it will start straight away but more often than not it will turn over for ages before firing up nearly flattening the battery |
| Back to top |
DONFRAMAC
Posted: Tue May 13, 2008 3:11 am Post subject: |
I have found that Continental spark-plug leads suffer from "damp-start" problems.
The cheap cure is to paint Waxoyl onto the joints at the end-fittings of the leads: a spray with WD40 is temporary as it dries, leaving a sticky residue.
Next, renew the distributor cap and rotor-arm.
If still unreliable, the earth-strap from the bodywork to the engine/gearbox, could well have white furry corrosion-products needing scrubbing off with a wire brush, between the braided ends, and the body/engine. Apply vaseline under the end-fittings will delay the return of corrosion-products.
New H.T. leads and platinum-tipped spark-plugs, would be my next task. |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
