Wall Multi Starter Kit
Product Review Summary: We tested the wall multi starter kit for tying brickwork into existing structures. Find out what we thought of it and how well it works in this product review.
Wall Multi Starter Kit Review
Buy now from Screwfix
Product
PRODUCT:
Manufacturer: Sabrefix
Model Number: Screwfix 66650
Type: Wall multi starter kit
Included in the Box:
  • 2 x 2.1m lengths of channel
  • 5 coach screws with washers and plugs
  • 10 ties
Special Features:
  • Easy slide channel
  • Lightweight
Reviewed by: The DIY Doctor
4 Stars
(4 out of 5 stars)
Easy to use fixing kit but not enough fixing screws supplied as shown on the video. Nuts are 10mm not 13 as shown in instructions but the kit does exactly what it says on the tin. The holes on the channel allow plenty of room for an 8mm drill to pass through and the channels allow the ties to slide down easily. The ties must be kept square to the channel or they will slip out. This kit is not as robust as some we have used but will do the job and with some extra fixing screws (you can use 2 inch number 12 screws with a washer to make up the shortfall in coach bolts) you can get a good solid starting point for your walls.
