Eddy Water Descalers
WELCOME TO OUR COLD WATER SYSTEMS PROJECT
Summary: Different types of Cold Water Systems that can be found in your home
Cold Water System
Indirect cold water system. Water comes into house via rising main, is branched off to feed at least one tap (in this case the kitchen and outside tap. It also feeds the boiler next to the sink) and then continues to a storage tank in the loft. From here it is distributed to the other taps in the house. Overflow pipes are marked O. The position of stopcocks etc is marked on the diagram below which also shows the hot water path.
Cold Water System
Click to enlarge
The bottom picture shows a direct cold water system, where cold water is distributed all over the house at mains pressure.
Direct Water System
Click to enlarge
