WELCOME TO OUR COLD WATER SYSTEMS PROJECT
This project is presented by www.eddy.uk.com
Summary: Cold Water Systems
Cold Water System
Indirect cold water system. Water comes into house via rising main, is branched off to feed at least one tap (in this case the kitchen and outside tap. It also feeds the boiler next to the sink) and then continues to a storage tank in the loft. From here it is distributed to the other taps in the house. Overflow pipes are marked O. The position of stopcocks etc is marked on the diagram below which also shows the hot water path.
Cold Water System
Click to enlarge
The bottom picture shows a direct cold water system, where cold water is distributed all over the house at mains pressure.
Direct Water System
Click to enlarge
Forums
Plumbing
Post new topic
No new posts WC Flushing Problems
1 jims2 28
plumbbob View latest post
No new posts connecting to 1/2" pipe
1 alight 31
No new posts No Water at all - Help!
1 Dazed and 33
bobplum View latest post
No new posts Plastic pipe
3 wey aye m 78
No new posts Drilled through water pipe in wall
1 Syd 56
No new posts Combi boiler but not enough water pressure
1 SHL 29
No new posts overflow on electric shower pouring water.
4 Ann Batch 59
No new posts Stuttering shower
6 Akash 272
No new posts No cold water from tank in loft to shower
3 Jim the p 70
No new posts hot water flow from fire back boiler - pipe stat/pump wiring
3 jackie we 224
alanfr View latest post
No new posts thermostatic shower mixer tap dripping
0 lenvos 17
lenvos View latest post
No new posts Only one radiator not working!
3 jayned 109
Steve the View latest post
No new posts Radiators in front room and hall dont heat up! Cold! Help
2 james00j 104
No new posts Flush loo with rain water
14 NigelG 929
No new posts Insatall separate Shower Mixing Valve set up.
1 Bob Savag 47
No new posts Only lukewarm water at max setting; Thermostatic Shower
9 noviceher 323
No new posts Lockshield valves wide open - why?
7 midknight 186
AdamsHeat View latest post
No new posts Removing a sink
2 Did it my 65
Did it my View latest post
No new posts WATER SUPPLY
0 WIT TANKE 34
WIT TANKE View latest post
No new posts confused
1 blink23 61
No new posts WATER PRESSURE
1 shiftyf19 107
No new posts keston celsius 25 problem firing
4 baldilock 125
No new posts Push down button for Toilet
1 twinmum71 135
No new posts Bad radiators
4 hazli1 146
chris_on_ View latest post
No new posts TOILET CISTERN
1 L&A 136
No new posts Difficukt ti get in to hot water
2 cerclefor 107
cerclefor View latest post
No new posts urgent help with baxi 80he boiler
1 bjenkins 99
gazwads View latest post
No new posts Problem fitting branch pipe for new WC
6 mcardellg 328
mcardellg View latest post
No new posts Cold water storage tank moving
1 whinger69 61
No new posts Dismantle mixer tap
0 davel 112
davel View latest post
No new posts Odd Boiler/Water Tank Problem....
2 Ian Sheri 228
Ian Sheri View latest post
No new posts bottom of shower box leaking - can i fix this
2 tipsymcsw 302
nitro2345 View latest post
No new posts No hot water
0 trevor8 98
trevor8 View latest post
No new posts Lockshield valves fully open - is this right?
0 midknight 74
midknight View latest post
No new posts worcester 24cdi
4 topdec 206
No new posts No hot water - Help!
3 Roz 217
No new posts Flushing Central Heating System
6 kbrownie 388
No new posts reducing a vent pipe
0 jbaldwin 85
jbaldwin View latest post
No new posts Water too hot!!
4 STANO1234 195
No new posts Single Pump for Hot Water
3 scotzman 133
No new posts Toilet Cistern drop Valve Loud clunck
1 McC 98
No new posts Mixer Shower - Temp. Dropping
3 ChrisJohn 189
No new posts Filling shower tray
3 tom.wolst 196
No new posts No HW after powerflush to CH
7 Jen_new_h 253
Dave From View latest post
No new posts Radiators heating when off
2 usguvna 234
No new posts Electrics for shower
1 SC81 122
No new posts New Downstairs Bathroom
2 timwicks 95
No new posts Radiators to first floor now not working
3 golfing19 225
golfing19 View latest post
No new posts Hot water is not hot
2 pani 183
No new posts no hot water to the taps!!!
5 cameronlo 310
Display topics from previous:
Post new topic     -> Plumbing
Jump to:
Berkshire School of Plumbing
© Copyright Diydoctor Ltd 2008  Developed by Boson Media  Hosted by Rackspace
