Dry Rot and Wet Rot Pictures to Help With Detection, Diagnoses and Treatment
Summary: A Quick Picture Guide to Detecting, Diagnosing and Treating Dry Rot. How to tell Dry Rot from Wet Rot. Our Quick Guide on the Treatment of Dry Rot in Timber.
Pictures of Dry Rot and Wet Rot
Identification of your rot is the first part of this important process, these picture help you identify and diagnose different forms of for so you can treat it effectively. It is intended to give you an easy insight into the types of rot and treatment, but we also have further information on the difference between wet and dry rot and the processes and products you can use to treat dry rot. See our other project page for more in-depth information on diagnosing and treating rot. It is a worthy point to note that dry rot can seriously damage your property so if you suspect that it is present it is well worth getting professional advice. In respect to expert advice, Property Repair Systems are on hand to offer specialist information, call them on 01626 336 180, no charge and no obligations!
Dry Rot Strands
Dry Rot Strands or Hyphae
Dry Rot
The strands that you can see when dry rot starts growing look like roots. They are white, off white or even silver grey. When these strands dry out they turn brittle, where wet rot would stay flexible.
Wet Rot Strands Coniophora Puteana
Wet Rot Strands or Coniophora Puteana
Wet Rot
Coniophora Puteana – known as the 'cellar fungus'. The strands are dark – grey, brown or black. They form fern-shaped patterns. When they are dry they remain flexible. Occasionally they will form an olive-brown fruiting body, but this is very rare.
Fibroporia vaillantii – also known a cellar fungus, this looks similar to the fungus above but it has bright white strands, and have white fruiting bodies and spores.
Wet Rot Asterostroma
Wet Rot strands Asterostroma
Asterostroma – this has very fine brilliant white strands. The fruiting body has tiny star-like structures, but these are only visible using magnification.
Sheets or Mycelium
Dry Rot Mycelium
Dry Rot Sheets or Mycelium
Dry Rot
As you can see from the picture, this is a dirty off-white sheet, which forms a kind of skin on the surface of the affected timber. It can sometimes be yellowish or slightly lilac coloured, but it is not a bright white – a brilliant white skin would indicate wet rot rather than dry rot.
Wet Rot Mycelium
Wet Rot Sheets or Mycelium
Wet Rot
This is more of a skin or coating, and the wet rot is a bright brilliant white.
Fruiting Body or Sporophore
Dry Rot Fruiting Body
Dry Rot Mushroom, Fruiting Body or Sorophore
Dry Rot
This is the mature version of the fungus and this is the part that produces spores. Spores are the method that the dry rot uses to spread throughout the timber. They are rather like seeds in that they land on timber and look for the right conditions to start growing.
The fruiting body of Dry Rot is usually rusty red and/or ochre yellow with an off white outer edge. There could be touches of lilac or silver grey here too. You will often be able to see the red spores in the middle. It is usually a flat body which looks a bit like a tree mushroom you might see in woodland.
Wet Rot Fruiting Body
Wet Rot Fruiting body or Mushrooms
Wet Rot
These are the tiny fruiting bodies of wet rot they are small mushroom like fungi that are off white.
Dusting or Spores
Dry Rot Spores
Dry Rot Spores are Rusty Red
Dry Rot
The spores are rusty red and will be cast about by the mature fruit to land on all available surfaces. By blanketing the area in the way the fungi is hoping that the spores will find an area where they can flourish and grow. This is rare to find because the rot is usually discovered and treated before the fungus can get to this stage.
Wet Rot Dusting
Wet Rot Dusting Caused by Wood–Boring Weevils
Wet Rot
This dusting is not from spores, but from the activity of wood-boring weevils which only affect timber which is already rotting. It looks like sawdust, because that is basically what it is.
Wood Cracking or Cubing
Dry Rot Causing Cracking in Timber
Timber Cracking Caused by Dry Rot
Dry Rot
The wood forms deep cracks along the grain (the length of the timber), and then smaller cracks form across the grain to form a cube-like structure. 'cubes'. The wood can also shrink and curve inwards.
Wet Rot Causing Cracking in Timber
Timber Cracking Caused by Wet Rot
Wet Rot
Wet rot does display similar symptoms but the dry rot tends to form bigger and more irregular cubes, where the wet rot forms smaller and more regular cracking.
Dry Rot Treatments
Boron Powders and Solutions
Boron Ultra 12 timber treatment for rot and insects
Boron Ultra 12 Timber Treatment from Property Repair Systems
The best, safest and most pleasant treatment to apply is a product called Boron Ultra 12 which you can buy from Property Repair Systems as a powder or ready to use. This Borate is a water-based 'biostat'. This means it has no ill-effect on non wood–boring insects or on mammals. This Borate is easily applied as two coats either by brush or spray, and it quickly soaks into masonry and timber. It is permanent and, unlike its main rivals, it has no vapour or smell. It is formulated so that it can only affect wood rotting fungi and wood boring insects. It will not affect bats (a protected species) or their main food, the common house fly, which does not eat wood and so never gets contaminated with any preservative.
Borax boron solution for dry rot and woodworm treatment
Boron Gel and Paste Treatments
Boron Ultra Gel Timber Treatment
Boron Ultra Gel Timber Treatment from Property Repair Systems
Damp patches and heavily infested areas of timber, should have an application of Boron Ultra Gel (pictured above) as well, to reduce the risks of future rot and provide an extra active ingredient.
Boron Ultra Paste Timber Treatment
Boron Ultra Paste Timber Treatment from Property Repair Systems
Permanently damp wood also needs injection with Boron Ultra Paste (above) together with the inserting Boron Ultra Rods (below). These can be placed into any vulnerable timber such as window frames, garden posts, or door frames.
Boron Ultra Rods Internal Timber Treatment
Boron Ultra Rods Internal Timber Treatment from Property Repair Systems
The so called 're–entry time' for all pesticide treatments is only 1 hour, or until dry, whichever is the longer. This guidance is set by the HSE (Health and Safety Executive – a Government body concerned with safe working practices).
Pets, birds and fish are not at risk from Boron–based preservatives, but do NOT apply alternative products which contain Permethrin (which can be found in most DIY stores) if you keep any pets, particularly fish – Permethrin is lethal to fish, even in minute quantities.
Additional Precautions Against Dry Rot
Dry Rot Paint
Dry Rot Paint
Dry Rot Paint available form Property Repair Systems prevent Dry Rot Spreading
Paint Dry Rot Paint onto unaffected areas around the affected area that you are going to treat, to prevent the spread of rot. Read more about the dry rot barrier paint on Property Repair Systems Website.
Dry Rot Paint forms a barrier to stop the rot from spreading
Dry Rot Paint from Property Repair Systems Prevents Dry Rot Spreading to Unaffected Areas
The picture above shows panels treated with the paint on the right and untreated panels on the left. The two columns of treated panels have been painted with PRS Dry Rot Paint and show no signs of mould or fungal growth!
So, you can further reduce the risk of future Dry Rot attack by using the 'No Go Zone' Rot Barrier Paint by Property Repair Systems. This special emulsion paint can be applied behind skirting boards, into window frame reveals and in timber joist sockets. The paint, which has been tested by BRE (Building Research Establishment – a Government backed Test Authority) prevents Dry Rot from passing across treated areas. We know of no other treatment that can currently offer this feature.
If you need any help with any type of Wood Treatment or identification of wood rotting fungi including Boron treatments, the Property Repair Systems staff will be pleased to give you completely free, no obligation advice – 01626 336180
If you want to replace timber skirting boards – here is a video to teach you how to fix timber to masonry
