DIYDoctor
How to Use a Paint Pad
Summary: Find out what a paint pad is, what benefits they have over using traditional paint brushes and rollers and how to use them correctly
For many years a brush was the only option when it came to painting a room. Then came rollers, and what an innovation they were, saving time and giving more even coverage. Now, the latest paint applicator is the paint pad. Find out more about them in our guide below.
What Is a Paint Pad?
Paint Pad ExampleA paint pad is a flat, usually rectangular paint applicator. It has an easy-to-hold handle on the back, and the front is foam covered in short, densely-packed bristles.
Paint pads come in different sizes, so that you can pick the size that is most suitable for the painting job you need to do. There are different handle types available too, so you can choose the one that you feel most comfortable with.
You can buy replacement pads to fit onto the handle, so when the pad gets old and worn you can replace it.
Why Use a Paint Pad?
Paint pads are easy to use, provided you have the right equipment. Buy a pack that has a tray with a built-in roller. This enables you to make sure you get the right amount of paint on the pad.
Paint pads give good coverage and a smooth, even finish. They are much cleaner to use than rollers, as there is no spray. They do need reloading more often than rollers, but they still do the job quickly.
Because of the smooth finish they give, paint pads are particularly good for ceilings. Make sure you get one that you can attach a long handle to, to make the job even easier.
As with any painting job, make sure you have protected the floor and any furniture left in the room, and wear old clothes. Paint pads are less messy to use than rollers, but with any painting job there is a risk that some paint will somehow end up where it’s not meant to be!
Paint pad paint tray with rollerFor the best results, use a specialist paint pad tray, which has a built-in roller. Even if you can’t get a specialist tray, a normal paint tray will be better than nothing. Pour some paint into the tray, and draw the paint pad over the roller. This will transfer paint from the tray underneath onto the pad. If you are using a standard paint tray, dip the pad in the paint and wipe off the excess. Make sure the pad is evenly covered, otherwise you’ll get a patchy finish.
Start painting in a corner of the room. Place the pad flat on the wall, and move it up and down gently. Use long strokes to spread the paint out well, and to stop your arm from getting too tired! Work in a section directly in front of you, to make sure the pad stays flat on the wall and the pressure stays even. Work your way across the wall, blending the edges as you go and refilling the pad frequently as needed.
When you’ve finished, wash the pad in warm soapy water and rinse well.
Forum
Proceed to Forum
Feedback
Recommend This Page
Trustmark and the NHIC
Alaris Kitchens
