WELCOME TO OUR LAMINATE FLOORING PROJECT
Summary: Laminate Flooring and fitting laminate flooring
Laminate flooring has become an extremely popular, inexpensive floor covering over recent years and its versatility enables it to be installed in every room in the house. Indistinguishable (using reputable makes) from real wood floors, and so easy to clean an ambience can be created which can give your home a unique sense of style and charm.
Laminate flooring is an interlocking flooring system that uses the tongue and groove method of joining the individual planks. This tongue and groove system can be glued together, or more recently, clipped together using one of several dry joint methods, each particular to its manufacturer. All laminate floors have, at the top, a "wearlayer". This is generally comprised of a melamine resin which gets its incredible durability, wear and stain resistance from Aluminum Oxide. Under this wear layer, is generally a "print layer" which is simply a photograph of a real floor. The whole lot sits on a backing board.
Underneath the backingboard many choose to install an underlay. There are several different types available. For more detailed information regarding flooring underlay and also types of laminate flooring visit our Laying Laminate Flooring Project.
Look for flooring with some of the following attributes.
HDF.PROTECT is a registered method of using a high density fiberboard, impregnated with moisture resisting resins.
LOCTEC is a glue free installation. Simple and fast handling: Panels are simply locked into one another. Special profiling for a reliable four-sided lock. Can be walked on straight away. Thanks to tongue and groove sealing: no ingress of moisture possible if maintained according to our recommendation. Can be taken apart and laid again - ideal for house moves. No removal of residual glue necessary after installation.
SOUND PROTECT means optimum footfall noise absorption. thanks to an environmentally friendly, unique, dense integral underlay.
AQUA PROTECT means it is entirely suitable for the kitchen and bathroom. Highly resistant to moisture : a core board featuring a special component largely prevents swelling of the floor when in contact with water.
Laminate floors are hard wearing, resistant to household chemicals, hygienic, easy to clean and resistant to UV light (> level 6 Blue Scale, EN 20105 B02). They are available for Domestic and commercial use with a range of usage levels in both categories. Some examples of available colours can be seen below.
Maple
Beech Example 1
Beech 1
Beech Example 2
Beech 2
Oak Example
Oak
Cherry Example
Cherry
For a detailed guide on how to correctly lay laminate flooring why not visit our laying laminate flooring project.
Check out our video sections on "flooring" and "laying laminate flooring" to watch a variety of films on installing a laminate floor.
Forums
Flooring and Floor Coverings
Post new topic
No new posts Laminating around hearth
3 matthill7 70
rosebery View latest post
No new posts Bathroom Flooring - Tiles or Amtico
1 Colin1 84
No new posts Nails or Screws
2 dma 92
No new posts sanding a very small room
0 Gardencit 84
Gardencit View latest post
No new posts Wood Border
0 CarlnSam 145
CarlnSam View latest post
No new posts Carpet tiles on walls and ceiling
1 modfather 246
stoneyboy View latest post
No new posts What to seal chipboard flooring with to protect against dirt
0 clc.sheff 270
clc.sheff View latest post
No new posts Laying carpet tiles on wooden floor HELP
5 desperado 613
rabbit View latest post
No new posts how to remove pva glue from laminate floor
1 lon101 355
Dan the m View latest post
No new posts Levelling concrete sub floor for laminate
2 SWally 684
SWally View latest post
No new posts How to lay vinyl floor tiles
1 DevonSpee 492
No new posts Gaps between floor boards
3 duncansha 2562
Tall Tone View latest post
No new posts Laminate flooring tutorial
3 john9159 2373
No new posts Flooring retailers in the UK
0 home& 183
home& View latest post
No new posts Wood floor on Concrete Subfloor
0 sc100 633
sc100 View latest post
No new posts Laying laminate flooring
1 jerryj 605
Neil77 View latest post
No new posts Flagstone Flooring
0 Penalltie 354
Penalltie View latest post
No new posts Carpet cleaning...
0 Adwer 377
Adwer View latest post
No new posts levelling
0 brickyboy 782
brickyboy View latest post
No new posts Kitchen Stone Flag Floor
0 bowker 498
bowker View latest post
No new posts Tiles over concrete
0 Danc 1002
Danc View latest post
No new posts Laminate floor over heated tile
0 Danc 401
No new posts Vinyl over heated tiles?
0 jezb 308
jezb View latest post
No new posts Screed Problems
0 Bolty 843
Bolty View latest post
No new posts laminate flooring
1 magoo 731
No new posts fitting laminate around a fireplace
2 magoo 870
mr_vampy View latest post
No new posts HELP BIG AIR BUBBLE IN THE MIDDLE OF LAMINATE FLOORING
2 mrsboop 943
mrsboop View latest post
No new posts Tyle glue getting rid of ?
0 Auntie 457
Auntie View latest post
No new posts floor tiling
0 odman 574
odman View latest post
No new posts 4 sided tounge and groove between joists
0 mor22 586
mor22 View latest post
No new posts Woodworm treatment questions
2 apcl73 662
apcl73 View latest post
No new posts restoring parquet flooring
1 hobbis 765
No new posts 18mm Oak Flooring
0 ads123 790
ads123 View latest post
No new posts Importing Floors
0 floorfitt 294
floorfitt View latest post
No new posts Ceramic tiling over vinyl tiles?
3 tcwh1971 934
No new posts Parawood Flooring Excessive Flexing
0 GoodGos 703
GoodGos View latest post
No new posts fungus growing under laminate floor
1 egrobier 782
No new posts Any building regulations for subfloor leveness?
0 metamood 630
metamood View latest post
No new posts Insulation under screeded floor
0 stevec118 951
stevec118 View latest post
No new posts Is an expansion gap in concrete needed?
0 CherylB 854
CherylB View latest post
No new posts laying tongue and groove on concrete
0 spikejack 1099
spikejack View latest post
No new posts Boarding over floorboards good idea or not?
0 Ribbo 1428
Ribbo View latest post
No new posts Lacklustre Slate Tiles
1 stace 573
No new posts Replacing baseplates on sleeper walls and joists
0 Ran Kamat 739
Ran Kamat View latest post
No new posts Advice Please
0 schnoo10 466
schnoo10 View latest post
No new posts how to make good disaster with hardwaxing
0 Jooles 532
Jooles View latest post
No new posts subfloors
0 captsavea 722
captsavea View latest post
1 moph 1153
No new posts Self leveling compound over grout on wood floor?
1 Pylo 1273
Display topics from previous:
Post new topic     -> Flooring and Floor Coverings
Jump to:
