WELCOME TO OUR PREPARING BRICKWORK FOR PAINTING PROJECT
Summary: Preparing Brickwork and masonry for painting. Painting external brickwork and masonry.
The first thing to mention in this project is that there are two reasons for painting external masonry. One is for the decorative effect and the other is to make an unsound surface waterproof. If you are considering decoration for waterproofing, please read our waterproofing external masonry project first.
Any masonry surface, as with any decorated surface, needs to be thoroughly prepared. Absolutely any decorating job is only as good as the preparation work that has gone into it, and paint, liberally and quickly applied, over unclean and unprepared surfaces, will not stand the test of time.
Brush your masonry clean. First with a stiff brush (a household broom is a good tool with its longer handle) Use a soft (brass bristles) wire brush on stubborn spots. It may be necessary to use a brick cleaning acid on really stubborn areas of old cement or existing, flaking paint.  A pressure washer can be used to clean masonry but if you do use one you must wait until your walls are completely dry before you paint. This takes, with continuous sunshine, about 3 weeks so we do not recommend it. Most masonry paints seal any damp in. This will result in the damp, as it cannot evaporate, turning to mould or trying to find a way into the building via those nice warm inside walls! If masonry is damp it increases the chances of a reaction with the salts contained in the masonry itself or the mortar. This leads to efflorescence. Heat loss through damp walls is three times greater than through dry walls.
When the surface is clean, check all the joints for holes. Paint is not a filler and if you have missing pointing, or lumps missing from bricks or blocks you may stand back to admire your work to find you have big black voids staring back at you.
Fill any missing joints with sand and cement mixed at 3 to 1 and push well into the brickwork. This mix can be used to fill holes in bricks blocks and stone also. For greater adhesion to the surface, mix a cupful of PVA adhesive with every bucket or even ½ bucket of mortar you use.
If your masonry has suffered from mould in the past, it is a good idea to treat it with a fungicide wash first. These are widely available from DIY stores and decorators merchants and simply brushed on, left for 24 hours, and washed off. Remember that washing your masonry is not the same as power washing your masonry where water can be forced into and behind your walls.
PAINTING BRICKWORK AND OTHER MASONRY
Once the joints are filled and the surface is clean you can stabilise the surface. Masonry stabilising solution is also known as primer binder as it not only "primes" (gets ready for what is to come) the surface, but it binds any potentially loose dust spots and invisible, potential flakes together. It is not magical and it will not hold loose bricks together, but it will provide a more stable surface on which to paint. An added bonus is that it makes your masonry paint go further as it has already primed the surface and made it slightly less absorbent.
Another point to mention here is that most masonry stabilisers will not allow your masonry to breathe. The effects of "suffocating" masonry are mentioned above and are not pleasant, or inexpensive to deal with. Look for a stabiliser, such as the one shown in our project above, which will continue to allow the masonry to breathe. When paining look for microporous paint which, again, allow the mortar to breathe. Your local builders, or decorators merchants will give you advice on this and be able to order microporous paints for you. Even better is an anti-mould breathable paint.
Remember to stay safe and tie any ladders you use. Easy to erect scaffold towers can be hired from local tool hire shops and for very difficult areas it is possible to hire a "cherry picker" which is a mechanically operated. The towers and ladders above can be purchased by clicking through on them
Forums
[ Goto pageGoto page: 1, 2, 3 ]
Decorating
Post new topic
No new posts MDF doors
1 sian.stur 68
sian.stur View latest post
No new posts PAINT RUNNER
2 Libby 394
desles View latest post
No new posts removing adhesive from the back of tiles
2 john woot 68
PJ Fagan View latest post
No new posts Bubbles in wallpaper when painting
1 DBB 19
DBB View latest post
No new posts Skirting board queries
0 Mrs S 14
Mrs S View latest post
No new posts paint will not stick to newish plaster
0 openfire 37
openfire View latest post
No new posts This paint stinks!!!!
39 Sand_stor 15634
robinx View latest post
No new posts PAINT PEELING AFTER 1 DAY ! PLEASE HELP
1 vw754 540
eddieman View latest post
No new posts Painting hallway
0 Radcliffe 101
Radcliffe View latest post
No new posts Removing gloss from radiators
1 angela23 399
cmaxx View latest post
No new posts stain or varnish for oak
1 chocco 371
No new posts Sash Window Exterior Painting
1 mossy810 144
No new posts paint problem
2 westhighl 359
westhighl View latest post
No new posts Painting kitchen units (chipboard)
1 benjic 380
chris_on_ View latest post
No new posts painting exterior doorstep tiles
1 Vic112 193
No new posts glass wall splashbacks
1 maur4444 212
No new posts X-TX Artex remover.
1 plasterma 461
No new posts Paint or Wallpaper ?
2 jaffacake 387
No new posts painting.....a lamp?
0 worcester 79
worcester View latest post
No new posts Painting Exterior wooden door
1 BRU 218
gardnico1 View latest post
No new posts wall paper stripping problems
0 lemons 274
lemons View latest post
No new posts Jarred Windows
0 momo08 168
momo08 View latest post
No new posts exterior paint
2 reno32 324
reno32 View latest post
No new posts PAINTING --------a fire surround ?
0 vw754 323
vw754 View latest post
No new posts decorating external GRP woodgrain finish garage door
0 neilbrads 207
neilbrads View latest post
No new posts painting a varnished chest of drawers
1 heather75 418
thedoctor View latest post
No new posts painting flakey plasterboard walls
1 craig web 1655
lori View latest post
No new posts Wallpaper - sizing walls
1 Dino M 697
No new posts Rust Stains
1 Iestyn 334
No new posts Old emusion peeling prior to new wallpaper
2 paintbrus 489
paintbrus View latest post
No new posts How to Prepare for Painting Vinyl Wallpaper
2 saki 525
saki View latest post
No new posts Gloss paint - tiny bubbles
5 jeddy 688
jeddy View latest post
No new posts best way to fill in large hole before papering
2 lizzie 459
No new posts Coving a room where ceiling slopes at one end
0 Pete007 290
Pete007 View latest post
No new posts Shower curtain rail - just can't find the right one..
0 davej 277
davej View latest post
No new posts White Paint
0 gilesm 304
gilesm View latest post
No new posts advice sought on wallpapering stairs+landing!!!
1 D.I.Y. Da 443
No new posts Window sill repairs - fillers and stains question
0 novice81 351
novice81 View latest post
No new posts Window frames joined with sill
1 Small 325
stevenc16 View latest post
No new posts WOODWORKING PLANS
0 thedoctor 306
No new posts old emulsion
1 sugar 429
No new posts Not sure what to do thanks to husband silly idea.
3 nicolat78 1049
Sagalout1 View latest post
No new posts Filling in Holes drilled in kitchen wall
2 wils3957 401
wils3957 View latest post
No new posts how to paint new plaster/skimmed walls
2 vw754 1205
csjs20 View latest post
0 robinson 371
robinson View latest post
No new posts White Satin Paint
2 Tracejovi 528
Tracejovi View latest post
No new posts wooden floor protection...Tips req'd
0 1norab 341
1norab View latest post
No new posts Finishing coving at door frames
1 familylad 376
Newo View latest post
No new posts How to stop yatch varnish coming through white gloss
1 Pasht 448
Woodfinis View latest post
No new posts stripping paint from metal
1 LES EATON 408
Display topics from previous:
Post new topic     -> Decorating
Jump to:
Berkshire School of Plumbing
© Copyright Diydoctor Ltd 2008  Developed by Boson Media  Hosted by Rackspace
