DIYDoctor
LaFarge
Repairing Concrete Using LaFarge Repair Concrete
Summary: Find out how to repair cracks and splits in concrete and also patio slab cracks and joints using LaFarge Repair Concrete
This project is about how to repair a concrete path or step when it is possible to do so without breaking up the whole area. Repairing concrete in small areas cannot easily be done with a normal concrete mix as the aggregate is usually too large for small areas and the stones in the mix make it very difficult to get a good finish.
Lafarge have made concrete repair very easy with their new DIY repair concrete. For more information on this product and also other products in LaFarge's ready mix and ready to use range visit the DIY Cement website. If you would like an over view of how to use this product read on below.
Repair concrete from Lafarge comes in 20kg bags or smaller 2.5kg tubs. 1 bag will be enough to repair approximately 0.22 square metres of concrete at a thickness of 25mm.
We do not recommend using repair concrete at any more than 50mm (2”) thick. Do not use when the temperature is below 5 degrees c or above 30 degrees c.
How to use repair concrete:
  1. Brush any dust or debris from the surface to be repaired and also remove any loose concrete that may be in the area to be repaired with a stiff brush or wire brush being careful not to cause further damage and dampen the repair area down with water so it is wet, but with no standing water remaining.
  2. Open the bag or tub of repair concrete and pour enough of the mix in to the area to be repaired ensuring that you have a good covering. Please remember no more than 50mm thick.
  3. Level out/off the mix using a trowel or straight edge of some kind, ensuring that the repair area is flush with any other adjoining areas and you will not end up with a proud repair that sticks out or above its surrounding surfaces.
  4. Use a watering can with a fine rose head to sprinkle water over the repair area and the mix until it is all wet. However please also ensure that you do not end up with and puddles on the mix. To ensure that this does not happen sprinkle the water lightly in stages until you get the required amount of water covering the mix.
  5. Concrete repair float
  6. Compact, or float the concrete using a polyurethane trowel as seen in the image to the right, ensuring that it is flat and smooth.
  7. Damp down the concrete repair area using the watering can and rose as you did in the previous step no more than 2 hours after the initial sprinkling and levelling. By doing this you can prevent the concrete from drying out too quickly and cracking due to shrinkage.
  8. Once you have completed the above steps and you are happy with the repair cover the area over with polythene (a bin liner will be suitable) for 7 days to ensure that it hardens off correctly without any disturbance. The initial set for this repair concrete is about 30 minutes but do not tread on it for 7 days until it has had a chance to harden off naturally.
    If the repair has taken place in a rather high traffic area such as a walkway or path etc.... then it may be a good idea to surround it with some cones or bollards etc.... to make sure that no one inadvertently stands on it and ruins the finish.
    To find out about creating other concrete mixes visit our mixing concrete project or if you would like more information on other products in the LaFarge ready mix/ready to use range visit the DIY Cement website
    Forum
    Proceed to Forum
    Feedback
    Similar Projects
Recommend This Page
Trustmark and the NHIC
Alaris Kitchens
