WELCOME TO OUR REPAIRING A BURST PIPE PROJECT
Summary: How to repair a burst pipe
INCLUDING:
  • Pipe lagging:
  • Nail holes in pipes
  • Burst pipe repair method
  • Slip on coupling
  • Compression join
  • Push fit repair
An unprotected water pipe will often freeze during the winter months, of which we seem to get about 11 per year in this Country!
Frozen water expands quite dramatically, and if contained in a pipe where no expansion room is available, the pipe will split. This in itself, is not the problem. The problem occurs when the ice thaws out again!
Rather than wait for a freezing spell and wish a burst pipe on somebody, we have used a pipe with a deliberate nail hole in, to explain the mending procedure.
Pipe with nail hole in
Pipe lagging:
Incidentally, burst pipes can be avoided with the correct lagging applied to them, the minimum recommended thickness of pipe insulation are:
  • 15mm pipe: 25mm
  •  22-28 mm pipe: 19mm
  • 35mm and over pipe: 9mm.
Nail holes in pipes:
Nail holes can be avoided by a careful search of the area you are nailing in with a pipe and/or cable detector. These are available from most diy stores at about £12.00.
Burst pipe repair method:
First turn the water off as soon as you realise there is a problem. A small amount of water will dry out, a large amount will cause a great deal of damage. If, when you are reading this project and you do not know where your main stop cock is; go and find it!
Locate the burst or nail hole, remember this may not be directly below the visible signs of water. The ceiling may slope, or the pressure may have forced a spray of water away from the actual split, so search thoroughly.
For a single nail hole or small split, proprietary slip on couplers are available from the plumbers merchants.
Slip on coupling cross section
These are lengths of copper pipe, threaded at either end. Using a pipe cutter, hacksaw or pipe slice, cut the section of pipe containing the split or hole, away. Make sure you have cut far enough back to a section of the pipe that is still completely round and not distorted by the burst or force from the nail.
Pipe slices
If a hack saw is used, you may need to file the ends of the pipe free of burrs, to slide the olives on.
Sliding coupling onto pipe
The olives slide into the slip on coupling and are compressed by tightening the nuts. This gives a seal as in any other compression fitting.
Slip on coupling:
Tightening both nuts
If the hole, burst or pipe distortion is longer than about 2 inches, you will need to insert a section of pipe. This is achieved by using two small compression couplers either side of the new section.
Compression joints:
Compression coupling
A compression joint, as mentioned above, is so called because of the compression of a brass ring, or "olive" against the copper pipe, by a nut tightening onto a thread. The openings on compression fittings are made to accept the pipe, and a small amount of the olive, which is accommodated in a small bevel machined into the fitting. The nut is then tightened, while the fitting itself is held fast with another spanner. The olive is compressed, forming a water tight seal between the pipe and fitting. Care must be taken not to overtighten these fittings as it can lead to squashing the pipe slightly causing the joint to leak. No amount of tightening, should that occur, will remedy the situation.
Compression coupler
Push fit repair:
The easiest way to effect a repair in a leaking pipe is with a push fit system. Simply cut out the burst, as described above, and push on this purpose made repair pipe.
Push fit repair
All tools and fittings described in this project are available from our suppliers section, in the tools category. See the screwfix entry at the bottom of the page.
Why not check out our video sections on "repairing a burst pipe" and "plumbing tips" to watch some films on how to tackle this problem.
